HELP! Engine very rough after start up.
Old Feb 2, 2013 | 01:05 PM
MiamiPSD's Avatar
MiamiPSD
Here we go again. This truck is going to drive me crazy. All was good till today when I started the truck, drove about 6 blocks and a rough engine, no power started. All my fluids and filters are good and up to date. I recently did my under valve cover harnesses....both new. Changed out my cps before posting and checked all the wires....and still I can start the truck, runs fine for 30 seconds and starts the rough idling. No engine light comes on and I do have tach working........ Where do I go from here?
Old Feb 2, 2013 | 01:40 PM
MiamiPSD's Avatar
MiamiPSD
checked IPR...no oil on contacts..Started truck, rough idle began, disconnected ipr....no difference, still rough
Old Feb 2, 2013 | 02:41 PM
Christof13T's Avatar
Christof13T
You mean you disconnected the icp...
Im leaning toward your replacement cps being bad.
Could always pull your actual ipr, pull it apart...clean,and reassemble.
Try ohming out your ipr coil.
Old Feb 2, 2013 | 02:57 PM
MiamiPSD's Avatar
MiamiPSD
tried multi - cps, still the same
Old Feb 2, 2013 | 03:56 PM
MiamiPSD's Avatar
MiamiPSD
Come on guys.........you can debate a chip vendor for days but cant help a brother......where is the help?
Old Feb 2, 2013 | 05:29 PM
MiamiPSD's Avatar
MiamiPSD
bumpppppppp
Old Feb 2, 2013 | 06:31 PM
Franko72's Avatar
Franko72
Molon Labe
If it feels like it's running on 7 cylinders I would think a loose armature.
If it shakes real bad and has ZERO power then I'm thinking a whole bank of injectors is out.
A buzz test is in order or you may have to pull the VC's.
You could always try the infared thermo on the exhaust ports and see if you have a cool cylinder.
Old Feb 2, 2013 | 06:57 PM
MiamiPSD's Avatar
MiamiPSD
It runs find after start up for 30 sec then goes to he..
Old Feb 2, 2013 | 07:35 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
When was the fuel filter last changed? Does it feel like it is starving for fuel?
Old Feb 2, 2013 | 07:36 PM
MiamiPSD's Avatar
MiamiPSD
Changed it today... Have 65 psi fuel pressur
Old Feb 2, 2013 | 09:44 PM
howellt39's Avatar
howellt39
Try ohming out your IPR coil or removing, cleaning, reassembling like Christof13T suggested, that's good advice.
Old Feb 2, 2013 | 09:59 PM
twg1966's Avatar
twg1966
You can also get the rebuild kit for the IPR from Riff Raff.
Riffraff Diesel: IPR Re-Seal kit
Old Feb 3, 2013 | 05:35 AM
MiamiPSD's Avatar
MiamiPSD
How would the ipr cause this problem? Starts fine, run fine for a 15 seconds then begins the miss.
Old Feb 3, 2013 | 11:21 AM
MiamiPSD's Avatar
MiamiPSD
Went out this morning, checked the drivers side UVC previous install....all looks good. Cleaned the connector real good prior to start up.......started up, ran find 30 seconds, started with same rough idle. Turned off truck, changed out computer to the stock one I had....same thing. this is really driving me crazy. Truck has 68K babied miles with numerous upgrades and I get this shi...........t. I guess I need to drive the living **** out of it. I really dont want to take it to the dealer cause its going to run me an arm and a leg........Guy, need help here.
Old Feb 3, 2013 | 03:55 PM
Pitcrw6's Avatar
Pitcrw6
Do you have AE that you can hook up to it and see some data?
