HELP! Engine very rough after start up.
Old Feb 3, 2013 | 03:57 PM
MiamiPSD's Avatar
MiamiPSD
Just ordered one from clay today
Old Feb 4, 2013 | 08:31 AM
MiamiPSD's Avatar
MiamiPSD
Any more idea guys..... Really need to get this fix, only means of transportation
Old Feb 4, 2013 | 09:56 AM
cps's Avatar
cps
How much fuel is in your truck? Have you ran it low recently? You might have some( plugged intank filters) restriction in your tank causing fuel pressure loss after 30 secs.
Old Feb 4, 2013 | 10:02 AM
MiamiPSD's Avatar
MiamiPSD
No....always keep it above 1/2 tank......have 64 lbs at regulator when the miss is happening. I have the in tank done, changed out all filters. It sounds like if the UVC harness was loose but then I changed them out with the new updated version.....even checked the drivers side since it was easier to see if something was left loose......
Old Feb 4, 2013 | 10:18 AM
Pitcrw6's Avatar
Pitcrw6
Did you look at the 9 pin connector for a burnt center pin? Or any burnt pins? That can cause your issue also.
Old Feb 4, 2013 | 10:22 AM
Pitcrw6's Avatar
Pitcrw6
Also, did you pull the VC's and look at each injector to see if its spitting out oil?
Old Feb 4, 2013 | 12:03 PM
MiamiPSD's Avatar
MiamiPSD
Would I need to crank the truck over to check
Old Feb 4, 2013 | 12:13 PM
cps's Avatar
cps
Yes. you might need to Ohm the harnesses from the IDM. Go to GB manufacturing for the info.
Old Feb 4, 2013 | 01:23 PM
MiamiPSD's Avatar
MiamiPSD
The IDM.....Is it a good no good deal here? The truck starts and runs fine for 20 sec.?
Old Feb 4, 2013 | 02:47 PM
cps's Avatar
cps
It is possible, you could have moisture intrusion causing corrosion which in turn could cause an electrical issue.Not that hard to check, just take the inner fender liner off on the drivers side. I would ohm out the wiring from the IDM. Engine vibration could cause a problem with a bad harness. Can you wiggle the wires while it is running rough?
Old Feb 4, 2013 | 03:45 PM
MiamiPSD's Avatar
MiamiPSD
OK, just finished with IDM circuit test. All is good, circuits are 3.0 across test one and open OL with test 2 and 3...............wiggled wires all over, still missing.
Old Feb 4, 2013 | 06:42 PM
cps's Avatar
cps
It is looking more like injector/oil issue. you will know more when you can hook it up to an AE.
Old Feb 4, 2013 | 06:50 PM
  #28
MiamiPSD's Avatar
MiamiPSD
What screens do you recommend to monitor on a AE... Will be first time user.
Old Feb 4, 2013 | 06:52 PM
  #29
MiamiPSD's Avatar
MiamiPSD
Really......I only have 68K miles on it......would an injector go bad. Im the original owner.
Old Feb 4, 2013 | 06:55 PM
  #30
MiamiPSD's Avatar
MiamiPSD
CPS, also, thank you for your helping. A forum so big with so many knowledgeable guys and no other seems to help, but lets talk chip vendors, gauges and other crap and we have wars............thanks again.
