302 or 255
Old Feb 1, 2013 | 11:13 PM
shapechanger101's Avatar
shapechanger101
302 or 255
So i have an engine, i believe it is a 302, but i have been told it could be a 255 which i don't want. I bought it from a friend who had it in an 83 fox body, he claims it is not the original motor, but he only owned the mustang for about 1.5 years before he sold the motor to be.
The casting code is E0AE DC3
next to it is a small place that is screwed on that read 3D8
and on the top rear behind the intake there is a partial vin that reads DHxxxxxx
So do i have a 302 or 255?
Old Feb 1, 2013 | 11:21 PM
85e150's Avatar
85e150
Look at the intake manifold. If it is open, requiring a valley pan, it is a 255. 302s have a solid intake, no open runners.
Said to be a 255:
http://i12.photobucket.com/albums/a2...427D4E67A1.jpg
From this thread:
https://www.ford-trucks.com/forums/1...53-f100-4.html
Old Feb 1, 2013 | 11:23 PM
shapechanger101
Said to be a 255:
From this thread:
Guess i should have put in the first post that it has an edelbrock performer rpm intake on it.
Old Feb 1, 2013 | 11:39 PM
85e150's Avatar
85e150
Edelbrock says that won't fit a 255:
Edelbrock.com - Manifolds - Ford - Performer RPM - 289/302/351W
Ports are oval, manifold might bolt up, but wouldn't work very well.
Old Feb 1, 2013 | 11:56 PM
shapechanger101
How well would it run if it was to be put on a 255? This engine ran pretty well when removed from the mustang.
Old Feb 2, 2013 | 12:01 AM
85e150's Avatar
85e150
They talk about port mismatch, so it would probably, at best, run just like a 255 with 114 horse or whatever. I'd expect it to load up at idle or low rev running, as with a mismatch, you have 8 perfect spots for fuel to come out of suspension at low engine speeds.
Pull the heads, you want new gaskets anyway, and you want to look at those pistons as well.
dstraw
Jul 1, 2019 09:52 PM
Brian1971f100
13
Feb 19, 2017 12:45 AM
CraigerF100
Feb 9, 2013 03:39 PM
TheTowingCowboy
19
Oct 23, 2007 08:29 PM
rellikkcaj
Jan 19, 2007 12:58 PM
