steering box
Old Feb 1, 2013 | 07:21 PM
likefords's Avatar
likefords
steering box
have 64 f100 want to keep straight axel,till I can afford IFS. CAN I cut shaft from box n add a late model tilt column? can I cut n use rag joint n 79 tilt coulmn from 79 f100?
Old Feb 2, 2013 | 03:00 PM
garbz2's Avatar
garbz2
I have 64 f100 and i want to keep the straight axle until i can afford IFS. Can I cut the shaft from the integral box and add a late model tilt column? Can I cut and use rag joint and the 79 tilt column from 79 f100?
Now it is understandable.
Yes you can do all this it takes a bit of fabrication skill. The 79 Tilt will need to be modified to make the attachment.
The box can be modified to accept a rag joint however it will need to be machined with the correct spline count. Way to much money to have done as the shaft has to come out to have it done.
If you are going to use the column when you eventually add IFS i would use a round to round Borgeson joint and pin it to the original box and the lower shaft of the tilt.
You also will need to restrain the column at the floor board with a mount.
Lots of work for little benefit.
Garbz
Old Feb 3, 2013 | 12:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978/79 F100/350 tilt 'columns' were not available with 3 speed manual trans. A/T and 4 speed manual only.
The steering wheel itself tilts, not the column and is operated by pressing the T/S handle forward.
70Broc
Dec 27, 2012 06:55 AM
doug70
Jan 18, 2011 10:45 AM
FordEdselFanatic
Apr 19, 2009 04:30 AM
79 F-150 Stone
Jan 13, 2006 10:21 PM
jaye
Jul 28, 2002 11:38 AM
