tilt steering column
Old Jul 28, 2002 | 09:11 AM
jaye's Avatar
jaye
I'm thinking about putting a tilt column in my 55. I have the toyota box and only have a few inches to play with is it necessary to have a damper or some type of free floating shaft between the box and the column or can I connect the column directly to the box.
Jaye
Old Jul 28, 2002 | 09:28 AM
Jimbare's Avatar
Jimbare
all alone in the world
you will need some sort of a flex connection between them. with body movement and frame twist it is not a good idea to hook the column directly to the steering box.
Old Jul 28, 2002 | 10:31 AM
jniolon's Avatar
jniolon
old and in the way
Jaye,
how much is a few ??? 2 or 6?? you can find most everything you could need at Borgensen... look at my article on tilt column install for some suggestions... the intermediate shaft can be any length or you might get away with just one universal... if it's really tight you could simply use a rag joint like the factory installs...I agree with the direct connect... it's not the best..
john
look here...left frame
http://jniolon.clubfte.com :-)
Old Jul 28, 2002 | 11:38 AM
Kenny's Avatar
Kenny
