79 4x4 steering column build
Old Jan 17, 2011 | 01:44 PM
doug70's Avatar
doug70
I am building a 79 F250 4x4 and someone destroyed the column. Cut sheet metal and destroyed all but the inner shaft.
I took the column out of my 73 4x2. If I disassemble it and use the inner shaft from the 79, will it fit? The 73 4x2 column is mint. What else should I do? Turn signal switch...
Doug
Old Jan 18, 2011 | 07:43 AM
doug70's Avatar
doug70
No-one has done this? Well I will try it today and post my results.
Doug
Old Jan 18, 2011 | 10:45 AM
doug70's Avatar
doug70
Update
Ok, Here is what I did.
79 F250 4x4 steering column from parts truck that was trashed
73 f100 4x2 steering column Perfect
Pulled center shaft from 79 column
pulled center shaft from 73 column
installed 79 shaft in 73 column and reinstalled
used 79 steering shaft(will replace later with collapsible shaft)
Works fine.
Doug
DW SD
Oct 16, 2013 05:55 PM
doug70
20
Sep 28, 2010 05:20 PM
doug70
Sep 16, 2010 12:03 PM
doug70
Jul 23, 2010 02:10 PM
doug70
Offroad & 4x4
17
Jul 17, 2010 04:00 PM
