Car question
Old Feb 1, 2013 | 12:18 PM
eatfish's Avatar
eatfish
Car question
1997 Taurus Wagon
3.0 v6 automatic
Sorry, it's not a truck but thought someone might be able to help here.
Many times, when I come to a stop the transmission feels like it shifts to neutral and I have to give the car some gas to get it to go. It feels like popping a clutch, not like it is slipping. Other than that, the tranny shifts fine and doesn't slip.
Is there any adjustment I can do to help with this? Any part of the valve body that could be malfunctioning/plugged that might cause this?
Over 200,000 miles on the car and would like to run it as long as I can.
Thanks for the help.
Old Feb 1, 2013 | 12:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I can't think of anything in the valve body that could do this. There is nothing anywhere on the trans that is adjustable.
If it isn't low on fluid I suspect a worn seal in the forward clutch, or even more likely a cracked forward clutch piston.
Old Feb 1, 2013 | 12:54 PM
eatfish's Avatar
eatfish
Thanks, I respect your thoughts. I guess I will just run it into the ground. It really isn't worth pulling the tranny for. Just hoping it was easy.
Edit: You were spot on, thanks for giving me something to google. Found all the info I need.
Old Feb 1, 2013 | 02:55 PM
Mark Kovalsky
Been there, done that, had a '97 Taurus with a cracked forward clutch piston.
Old Feb 8, 2013 | 06:15 PM
wilcam47's Avatar
wilcam47
torque convert going out possibly?
Old Feb 8, 2013 | 07:33 PM
Mark Kovalsky
No, it isn't the torque converter. It is the forward clutch piston.
orips66
Bronco II
Nov 10, 2018 11:54 AM
46Whizzer
Nov 7, 2016 02:34 PM
FordOwnerJoey
Nov 7, 2012 09:43 AM
bkcraun123
1983 - 2012 Ranger & B-Series
13
Feb 8, 2006 04:38 PM
WillAshland
Mar 8, 2004 02:49 AM
