Difference between ICP sensors
Old Sep 28, 2021 | 10:51 AM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Sous
Talking about ICP choices going forward... Over on the SD sub-forum we seemed to have noticed a bad run of ICP's coming from OEM suppliers a few months ago. Similar to the Alliant UVCH (1999 - 2003) that are now on backorder because Alliant themselves said there was a "problem with their manufacturer and quality control" and all supplies have been pulled back.
Anyway, an FTE'r ( @FordTruckNoob ) identified an alternative to the Motorcraft/International ICP as one made by Honeywell.
Link: https://www.ford-trucks.com/forums/1...l#post19958254
The longevity, life expectancy and feasibility of the Honeywell ICP is still in question though. I have linked it and provided it here simply as an alternative to OEM as these engines get a little older each day. There may be a day when we need to source reputable sensors from non-OEM sources due to lack of production or poor quality control practices by the manufacturers.
In addition, some information on counterfeit Motorcraft parts/sensors is below.
Link: https://www.ford-trucks.com/forums/1...are-clues.html
Good luck out there!
More info on aftermarket sensors here also: https://www.ford-trucks.com/forums/1...l#post19902498
Old Sep 28, 2021 | 12:53 PM
blageurt's Avatar
blageurt
OK I did not know that...thanks for Info...SO It could be possible that the 2 spare ICP's I bought from the International dealer close to my House over 8 years ago are NFG ? That would suck....
Old Sep 28, 2021 | 02:02 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Not at all... I would suspect that your 8 year old ICP's are GTG (good to go!) Just stating that as our engines age, manufacturer practices change and potentially become more "forgiving" in the tolerances and/or the OEM suppliers just stop making the sensor, the Honeywell ICP that FTN discovered may be an viable alternative.
It is good to have options, especially when the traditional option is no longer valid.
Old Sep 28, 2021 | 02:20 PM
blageurt's Avatar
blageurt
Ok cool ..I usually buy International sensors since they made the engine ...and I get them at Trade Price plus the dealer is close and a Huge Sales & Service place , one of only 2 in the GTA ( Greater Toronto Area ) .Just considering the School Bus Fleets there is alot of T444E's still running up here....
golfmedik
6.7L Power Stroke Diesel
15
Dec 31, 2023 05:47 AM
400 .040over
Electrical Systems/Wiring
May 5, 2012 09:10 AM
Elohim1
May 9, 2011 06:21 AM
korbon
1997 - 2003 F150
Aug 9, 2010 12:50 PM
