6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Leveling Kit
Old Jan 30, 2013 | 07:57 PM
joverstr2's Avatar
joverstr2
Leveling Kit
Wanting to install a leveling kit on my 08'. I would like a very good quality 2" kit. From the little research I have done so far, they are ranging in price from $40 - $200. I have stock tires right now, but will be upgrading in the near future. Probably something like Goodyear Wrangler DuraTracs.
Can y'all point me to a kit that you recommend? I would like to see pictures also if anyone has them.
Thanks
Old Jan 30, 2013 | 10:13 PM
finaddict's Avatar
finaddict
Icon 2 1/2" lift kit with Icon (Bilstein) shocks. Its more expensive, but with full replacement coil springs (graduated spring compression) , Caster adjustments and the shocks its well worth it. The ride is better than stock (soft in light compression and stif in full compression) rarely bottoms out and so far with 20,000 miles no death rattle without installing adjustable trackbar.
I am very happy with mine.
Old Jan 31, 2013 | 11:58 AM
joverstr2's Avatar
joverstr2
Old Jan 31, 2013 | 07:28 PM
finaddict's Avatar
finaddict
Yeah it will work, but you'll likely suffer from the "Death Wobble" , you'll need to buy an adjustable track bar to comepensate (about $300), you'll still have to look for caster adjustments and it won't ride as well. Mine was about $650 on Black Friday 2 years ago.
Old Feb 13, 2013 | 03:53 PM
countryboy73703's Avatar
countryboy73703
any input on the bottom mounted spacers? my buddy gave me one off ebay but not sure if I want to use it or not, cause it mounts on the bottom of the coil rather then a top,and it's a 3", but it comes with a 1" block for the back, and it comes with the shock bracket extensions for the front... just not sure if botom mounts are any good or not, caue I mostly see the top mount spacers..
lasallen
Apr 16, 2018 01:24 PM
onuredneck707
Feb 27, 2011 08:37 PM
jda1961
2009 - 2014 F150
Jun 5, 2009 07:27 AM
SDTruckMan
2004 - 2008 F150
Aug 24, 2007 07:58 PM
MRBASS
Feb 1, 2004 08:40 PM
