Sick 7.3
Old Jan 30, 2013 | 07:31 PM
coffeewithlofy's Avatar
coffeewithlofy
Sick 7.3
Looking for some advise.
Have a 03 f350 7.3ltr, 6speed manual. smoking on accelerationwhen hot. Blue smoke...Also blue smoke at cold start up. The colder the more it smokes.Trubo whines 1500rpm free spool no load. turbo does not whistle anymore although I still get 26plus lbs boost at full load. Motor is stock except for Banks Brake, 4" exaust, Banks programmer/chip. No cat. on exaust.
I am betting turbo is bad????? 132,000miles
Any advise?
Thanks,Mark
Old Jan 30, 2013 | 07:48 PM
srteach's Avatar
srteach
blue smoke means:
  • fuel not completely burned
  • on engine start: the engine is cold and the glow plugs aren't working correctly. search for how to check GPR (Glow Plug Relay) and then you can check the Glow Plugs themselves.
  • I have never seen blue smoke under load when hot. Smoke under load is (in my experience) black. Something is amiss there, I think.
On the turbo, pull of the intake tube and see if you have free spinning turbo, with minimal up/down, side/side and in/out movement. The impeller should not be touching the intake housing.
Old Jan 31, 2013 | 09:33 AM
Brother Les's Avatar
Brother Les
bump......
Old Jan 31, 2013 | 09:37 AM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Am I missing something here. I thought that blue smoke indicated the burning of oil. White smoke indicated unburnt fuel and black smoke indicated incomplete burning of the fuel or over fueling with a lack of oxygen. I would like to make certain I have a good understanding. I know someone will correct me if I am misunderstanding the smoke issue.
Old Jan 31, 2013 | 10:30 AM
srteach's Avatar
srteach
I guess it depends on what you define as blue, black or white.
White to me is steam out the exhaust. Usually smells like coolant.
Black, I agree with your definition. Don't sniff it.
Blue is unburned fuel out the exhaust. Smells like diesel.
These are my definitions as far as smoke, others may have different definitions.
Old Jan 31, 2013 | 10:34 AM
coffeewithlofy
Smoke has strong smell like burnt oil. Massive amount when you apply throtle.
Old Jan 31, 2013 | 10:36 AM
Brother Les
This might be of some help to read.
Diesel Smoke tells YOU a Story…
(I am not endorsing any products on that page, it is posted only for 'smoke' info)
Old Jan 31, 2013 | 10:54 AM
twg1966's Avatar
twg1966
Wow, I have a good understanding of the smoke issues based on that article. Thanks Brother Les.
coffeewithlofy
Jan 31, 2013 04:08 PM
big island
May 16, 2008 08:11 PM
big island
General Diesel Discussion
May 16, 2008 02:44 AM
bruno6491
Mar 5, 2008 07:49 PM
dagren99
Jan 26, 2006 05:50 PM
