sick 7.3
Old Jan 30, 2013 | 07:03 PM
coffeewithlofy's Avatar
coffeewithlofy
sick 7.3
Looking for some advise.
Have a 03 f350 7.3ltr, 6speed manual. smoking on accelerationwhen hot. Blue smoke...Also blue smoke at cold start up. The colder the more it smokes.Trubo whines 1500rpm free spool no load. turbo does not whistle anymore although I still get 26plus lbs boost at full load. Motor is stock except for Banks Brake, 4" exaust, Banks programmer/chip. No cat. on exaust.
I am betting turbo is bad????? 132000miles
Any advise?
Thanks,Mark
Old Jan 30, 2013 | 07:30 PM
Tom's Avatar
Tom
Hi Mark, welcome to FTE!
A question like this is best asked in the 7.3L Powerstroke forum, as that's where most of our knowledgeable 7.3L owners spend most of their time. I'm going to move your thread down there, good luck tracking down your problem!
Old Jan 30, 2013 | 07:51 PM
coffeewithlofy
Thanks
Hey thanks Tom
Old Jan 30, 2013 | 08:10 PM
jeffreyt's Avatar
jeffreyt
By blue, do you mean light, almost white, or dark, almost black, or do you really mean blue? White smoke is unburnt fuel.
On cold start, if the glow plugs or glow plug relay isn't working properly, you will see white smoke. Also if there an issue with an injector you can sometimes over fuel a cylinder resulting in white smoke.
Black smoke, aka roaling coal, is usually due to fuel not burning efficiently (not enough air due to low boost).
Blue smoke is likely oil. If it is infact blue, I'm guessing its time for injector Orings. Also if the crank case vent is plugged, positive pressure can cause oil to leak at the seal at the turbo which goes right to exhaust and shows up blue.
My opinion, if you're hitting 24psi, your turbo is ok.
Old Jan 31, 2013 | 10:15 AM
coffeewithlofy
still sick
Thanks,
Smoke is blue, strong smell of burning oil. for sure oil. I will check crank case vent. I`m thinking oil seals in turbo because of the no load load whine when you give motor a little throtle and 1500rpm? Maybe a bade bearing??
Old Jan 31, 2013 | 11:08 AM
jeffreyt's Avatar
jeffreyt
It all depends on the whine. I'm no expert on the turbo, but stock doesn't have ball bearings like the 38R does. You could look for play in the shaft to see if the wheel might be rubbing against the housing.
Old Jan 31, 2013 | 12:14 PM
coffeewithlofy
still sick
Thanks will check play today...
Old Jan 31, 2013 | 03:26 PM
JWAbercrombie's Avatar
JWAbercrombie
Check your fuel bowl for oil
Check your fuel bowl for oil in it. Mine started that and then got where it wouldn't run hardly at all. A busted oring on an injector will cause it to force engine oil past injector into fuel system.
Old Jan 31, 2013 | 04:08 PM
coffeewithlofy
thanks I will check fuel bowl for oil in it.
Mark
coffeewithlofy
Jan 31, 2013 10:54 AM
15 and 92 Dad
Jun 1, 2011 12:55 PM
big island
May 16, 2008 08:11 PM
brabe
Oct 30, 2003 10:12 PM
Nate9982
Sep 26, 2003 11:07 AM
