Alternator Problem?
Old Jan 30, 2013 | 06:01 PM
jerryepark's Avatar
jerryepark
Alternator Problem?
I have a 1972 F100. It ran the battery dead, and now it won't start, it'll only turn over.
The battery is brand new, and I've tried jump-starting it.
Old Jan 30, 2013 | 06:21 PM
rustywheel68's Avatar
rustywheel68
sounds like you have more than one problem. if you can't jump-start it, then something is wrong in addition to the dead battery.
you're gonna have to take it from the top-
are you getting spark to the plugs?
Old Jan 30, 2013 | 06:54 PM
jerryepark's Avatar
jerryepark
im getting a spark but its not starting all the way.
Old Jan 30, 2013 | 06:59 PM
rustywheel68
ok...maybe you've got 3 problems...
has anything else changed recently?
Old Jan 30, 2013 | 07:06 PM
jerryepark's Avatar
jerryepark
Has new belt
Old Jan 30, 2013 | 07:13 PM
rustywheel68
well- if you've got spark and its in time...then it sounds like a fuel issue.
so, a couple of questions:
1. how did you verify that you have spark?
2. have you checked the timing? to do that- rotate the engine until #1 is at TDC on the compression stroke. then check the timing marker.
Old Jan 30, 2013 | 07:21 PM
jerryepark's Avatar
jerryepark
it ran for about two seconds; and no, I don't know how.
Old Jan 30, 2013 | 07:23 PM
rustywheel68
ok- we'll go with what we've got.
if it ran for a couple of seconds and then died- i'm leaning towards a fuel issue.
have you got a can of starter fluid? hit it with a quick shot (a couple of seconds) and try it again.
Old Jan 30, 2013 | 09:59 PM
70-360fe's Avatar
70-360fe
I would also look in the carb while looking working the accelerator to see if your getting gas to the carb. Might want to get alt checked out.
How did it run before battery when dead. Wondering if your getting good spark, have you checked the points.
Old Jan 30, 2013 | 10:38 PM
Redmanbob's Avatar
Redmanbob
Originally Posted by jerryepark
Has new belt
Battery Dead: "Wont turn over at all"
Belt ? / Timing Chain/Gears ? (Timing set replaced or?)
Did you leave the ignition on by chance? Possible the condenser has failed, but if you have spark ?? good spark or orange in color ?
Check that the points gap is correct in the distributor (a match book cover on at points gap on the lobe is ok for gap test to start)
GOT FUEL ? I assume your not in a vacuum! With a CHIT LOAD OF SPARK AND FUEL!
Old Jan 31, 2013 | 11:47 PM
72Truckin's Avatar
72Truckin
If you have a starter turning, good battery and fuel... I would lean towards an issue with the distributor.
If the starter is turning very slow, good battery, then it could be a coil or your points and condenser not working properly.
Get a multi-meter and start testing your volts on the various components, with regards to starting the vehicle.
That would be my input.
1978FrankenFord
25
Apr 4, 2016 08:26 AM
StangPullerF250
Jan 12, 2011 10:05 AM
RoushChargedF-150
2004 - 2008 F150
Dec 29, 2010 03:53 PM
Bombdog1
Aug 24, 2009 10:08 PM
77_F150_4x4
Apr 4, 2000 11:34 PM
