Electrical problem, not battery or alternator?
Old Dec 29, 2010 | 01:28 PM
RoushChargedF-150's Avatar
RoushChargedF-150
On my 04 F-150, I have been having a problem with the electrical charging system. The battery keeps dieing, and I can't figure out why. I replaced the battery in October with a Duralast Gold battery. It didn't solve the problem, so I replaced the factory alternator with a 270 amp high output one, but I'm still having this problem. A lot of cold mornings, it won't even start, or other days it will do the thing were the gauages shake all crazy (which I think is a symptom of a bad battery). I took it to Autozone, where they tested the battery and alternator, and they said everything was alright. Im wondering do you think it could be a short somewhere or what? Also, is there anyway I can test how many amps im getting from the alternator? Any suggestions? Thanks
Old Dec 29, 2010 | 03:53 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
you have a ground somewhere that is draining the battery.
you've already replaced to 2 most common factors. now you need to start looking for shorts or other loads that are staying energized. have you recently installed any electrical equipment?
billneal
Electrical Systems/Wiring
May 5, 2013 05:02 PM
302flareside1992
Jul 27, 2010 11:53 AM
truthseeker
Jun 27, 2008 09:00 AM
bartspedden
30
Jun 28, 2005 07:51 AM
dland
Oct 16, 2002 08:23 AM
