Sponsored by: Real Truck
Battery or Altenator
Old Jan 11, 2011 | 08:22 PM
StangPullerF250's Avatar
StangPullerF250
First off I have a 03 F250 5.4. I ran into Target on the way home from work and went out and the truck wouldn't turn over and the battery died completly. I have never had a problem with the battery before. I have 48,000 miles on it and it is the original battery. My father-in-law tried to jump me and the truck would start, however as soon as he took the cables off, the truck would instantly shut off. Any advice would be great.
Old Jan 11, 2011 | 08:34 PM
StangPullerF250
I misspelled Alternator, I can't figure out how to fix it, sorry.
Old Jan 11, 2011 | 08:52 PM
IslaSkye's Avatar
IslaSkye
I'm sure there are bigger hats than mine around here... but it sounds like the alternator to me. I went through two in a short summer long ago, the first died while I was driving down a mountain road, the second when I stopped to make a left turn at a stoplight. Jumping didn't help and had to replace the alternator (twice). The second one was a factory problem so didn't cost me any more.
It might be worth pulling the battery and trying another as a test to see if it keeps running or not. If you know the "new" battery is good and it still won't run, I'd be thinking it was the alternator.
Good luck!
Old Jan 11, 2011 | 08:55 PM
BareBones's Avatar
BareBones
Well I don't know that I can speak to the modern generation of vehicles, but it used to be that you didn't need a battery in order to drive a vehicle, just to start it. In other words, there was no reason you couldn't remove a battery, yet have the vehicle continue to run.
If this is still true, the problem should be in the alternator, which most any parts store will test for you for free. Of course, given the age of the battery, now that its been completely depleted, its probably toast too.
Old Jan 11, 2011 | 10:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
From your description the battery is not charging. You need to figure out why.
It could be the alternator not putting out power, the battery not taking the charge or the even the cables got so corroded the current cannot get from the alternator to the battery or rest of the truck.
Chances are it is the alternator. I would pull it and have it tested at your local national chain auto parts store that can test these things..
Old Jan 11, 2011 | 10:50 PM
ganzey's Avatar
ganzey
like they said. but with the battery being 7-8 years old, it is probably nearing the end of its life.
Old Jan 11, 2011 | 11:39 PM
CraigOutdoors's Avatar
CraigOutdoors
I'd bet a benjamin it's the alternator. Same deal on my 00 Chevy, but the battery wasn't dead. I'd start it, it'd cut off battery power and switch to alternator and die. Just start and die as soon as I let off the key. New alternator and I was good to go. Sounds like these trucks will get juice from the battery if the alternator output is low. Good to get you off the side of the road should your alternator go out. Just put in a fresh one and get to cover.
Don't you hate it when they give you no warning they're going to break on you?
Old Jan 12, 2011 | 06:25 AM
gearloose1's Avatar
gearloose1
I am pretty sure a modern PCM will not work without the battery there.
So test is not definitive.
Try to measure alternator output with a clamp on ammeter, and simultanously measure voltage to get the wattage output.
If it is within 60% of max rated at 2,000 rpm, you are probably at minimum good to go.
e.g. a 110amp rated puts out at least 60% at 2,000 rpm (try a bit higher rpm as well)
The assumption is battery is flat... and you are just using all the juice you can generate (that is done by turning on everything electrical on in vehicle).
Old Jan 12, 2011 | 06:33 AM
StangPullerF250
Does anyone have a write up on changing the alternator?
Old Jan 12, 2011 | 08:33 AM
redford's Avatar
redford
From memory:
Disconnect negative battery terminal.
Remove air intake duct, if in the way.
Relieve tension on serpentine belt, slip belt off of alternator pulley.
Disconnect alternator wiring.
Remove mounting bolts and remove alternator.
To install, work backwards. It is also a good idea to put the battery on a charger while you are working on the alternator (away from the truck) so it will have a charge when you are done.
Old Jan 12, 2011 | 10:05 AM
deltasoft2009's Avatar
deltasoft2009
Yeah I go with the opinions too, alternator sounds about right! and although you may want to save money, it may be time to buy another great battery! Mine runs on duralast gold 8 yr warranty battery. Died on me once, zone gave me a new one back for low$....
changing the alternator is simple as edford described, just watch your hands as you release the torque on the nuts and screws and use a good rachet. Remember to grease up the contacts on the battery and do a cleanup on the terminals while tightening them back up. Just a thought ;-) Hope it helps!
