no spark
Old Mar 20, 2000 | 02:03 PM
77_F150_4x4's Avatar
77_F150_4x4
no spark
I was out chasing some 4 wheelers that were in my parents woods and my battery fell into the alternator now i put a diffrent battery in it all it does is lose charge and has little or no spark what should i do?????
Curtis
Old Mar 20, 2000 | 05:33 PM
jowilker's Avatar
jowilker
no spark
You could have purchased a bad battery.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Mar 20, 2000 | 06:30 PM
77_F150_4x4
no spark
no the battery is less than a year old we had it in out 74 jeep
Curtis
Old Mar 20, 2000 | 09:47 PM
hollibau's Avatar
hollibau
no spark
Fire the truck up and disconnect the positive lead to the battery and see if it stalls. If it does, you have an alternator problem. If it doesn't, your battery may be the culprit. I doubt you shorted out your alternator, but you may have disconnected one of the alternator wires. The connections to my '64 are difficult to see and I have to actually remove the alternator to see the wires. Just an opinion of how I would trouble shoot it.
Mike
Old Apr 3, 2000 | 01:13 PM
Eric_B's Avatar
Eric_B
no spark
Old Apr 4, 2000 | 11:34 PM
Superdave's Avatar
Superdave
no spark
77, This is one of those brother in law stories . He did the same thing as you in a 78 big Blazer, He chased this problem for weeks. Wound up having to put in an new alternator and battery together at the same time. Of course the GM had the voltage regulator built into the alternator. This is seperate on the Ford, (pass side below the hood hinge) He would install a battery and it would go dead in a couple of days or so. Then he would leave the used battery in and change the alternator, same thing. It seemed like they were reversing the polarity in each other. Try the voltage regulator and good battery together and see what happens.( that is if nothing else visible is seen, like a broken wire or etc.)Good luck!
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
PapaBearYuma
Nov 13, 2016 09:32 PM
mikeonetray13
23
Apr 26, 2015 11:02 AM
9440a4ld
1983 - 2012 Ranger & B-Series
Sep 2, 2014 09:06 AM
RIsuperduty89
Modular V8 (4.6L, 5.4L)
Jan 14, 2007 08:59 PM
frankster123
Electrical Systems/Wiring
Jun 8, 2003 06:54 PM
