AE urgent help
Old Jan 29, 2013 | 09:37 PM
eyyu's Avatar
eyyu
AE urgent help
I was playing with AE trying to make sense of my pressure readings. Everything is fine and fun until I happened to perform a koeo test. The AE said the there is an unknown failure and all or some of the relays keeps clicking and all dash lights keep flashing like a Christmas tree. The tach goes up and down. What did I just do?! Unplugged the AE, still doing the same thing. Truck won't start. What's wrong ? Erwin
Old Jan 29, 2013 | 09:51 PM
eyyu's Avatar
eyyu
Unhooked the negative terminals for a few minutes, hooked back up, still doing the same thing. Could it be that the koeo operation happened to screw up the ECM program? It was running a tow-safe tune from Superchips
Old Jan 29, 2013 | 10:15 PM
SkySkiJason's Avatar
SkySkiJason
Weird. Try unhooking the batts, then turn the key on for a few minutes before hooking them up again. This often 'resets' the PCM.
Hopefully someone who knows what they are talking about will chime in if that doesn't work.
Old Jan 29, 2013 | 10:20 PM
Pitcrw6's Avatar
Pitcrw6
This is a weird one. Try pulling out ur chip and see what happens. Make sure ur key is not in the ignition when u do it.
Old Jan 29, 2013 | 10:26 PM
Tugly's Avatar
Tugly
Leave battery disconnected before doing anything with chip or PCM
Old Jan 29, 2013 | 10:37 PM
eyyu's Avatar
eyyu
Well, very likely the cause is the"ever common" low batts. I hooked up my multimeter and it reads low. Changing the batts now. Will see what happens in the morning
Old Jan 29, 2013 | 11:13 PM
howellt39's Avatar
howellt39
Subscribing, because man that is scary. I want to see how this ends up before I fire up my AE nonchalantly.
Before I got "enlightened" by my brothers here, my regular code/live data reader would shut down my 7.3 if it was running. That was the end of that.
Old Jan 30, 2013 | 12:38 AM
SkySkiJason
Not sure the AE could directly cause this...
That said, I was fooling around with my Scangauge II last week in a friends '98 & '99 Mercedes 300TD's and got a surprise. No probs with the '99, but the in the '98 the GP relay was cycling on/off after the key was removed from ignition!! Since I had just done a ton of stuff to the car (veggie conversion), I was sure I messed something up. After deciding the only thing I changed right before this happened was plugging in the SG II - I unplugged it and everything returned to normal. In the meantime, its just a few more gray hairs - they add character right???
Old Jan 30, 2013 | 08:16 AM
eyyu's Avatar
eyyu
Just confirmed that the cause is indeed the weak batts. I stopped driving the truck as soon as there is salt on the road, only fire it up once a while. I guess it just happened that at the time I wast doing the koeo test, there is not enough juice in there. Well, what a scare! Should have more faith in AE. Thx all. Erwin
Old Jan 30, 2013 | 12:11 PM
01PS's Avatar
01PS
Sorry I didn't post on this sooner. I had the same issue the last time I pulled my chip. Bad connection on one of the batts and everthing went nuts. Thought I fried the PCM, but tightening of the terminals fixed me up. Glad you're back up and running!
DSMMH
Dec 13, 2014 05:20 AM
daveya48187
1983 - 2012 Ranger & B-Series
May 13, 2013 09:11 PM
mravetto
Jan 2, 2011 06:21 PM
foxracer800
24
Feb 17, 2009 07:38 PM
thump96
Oct 3, 2008 08:52 PM
