ignition module
Old Jan 29, 2013 | 03:11 PM
92blue on uhhhh blue's Avatar
Exclamation ignition module
truck died the other day. because its a pwner ford i still got it home by a combo of towing/ driving and the mechanic said he thought it was the ignition module and this was common . havent brought it to him cause dont really need it till this summer but my question is has anyone ever heard if this was common or had it happen to them before thnx in advance
Old Jan 29, 2013 | 03:18 PM
Conanski's Avatar
Conanski
There is a well known heat failure problem with these modules but that was when the modules were mounted on the distributor and your truck should have the fix which was to move it to the fender and mount it in a heatsink.
But don't go guessing and changing parts blindly you could spend a lot of money on the wrong parts, instead pull the codes first to see what has been flagged, if it's ignition related there will be codes for that, and if not then you have a fuel supply problem or something else.
73FordF100
25
Jun 12, 2011 11:51 AM
marty60
Jun 24, 2007 05:08 AM
1979FordF-250
May 25, 2006 02:23 PM
farmnaggie
Mar 7, 2006 08:44 AM
dc76
Feb 1, 2002 10:28 PM
