What in your opinion would be the best way to go. The truck has only 59000 orig. miles but it sat in a field for over 20 years. Because of that I rebuilt the engine so it could run on unleaded gas. I plan on camperizing the truck and want a good reliable ignition that will give me the best performance and fuel economy possible.
Pull a wiring harness and distributor out of a later truck or car with a blue grommet module and find a blue grommet Motorcraft Duraspark ignition module, not an aftermarket unit. Someone may be able to tell you the years the blue grommet was used in trucks and cars. The Motorcraft ignition module can be found in a boneyard also. Just get the ignition module tested at a parts store. Mount the ignition module with 1/4" standoffs on the inner fender back near the firewall.
With an OEM type unit you can get repair parts anywhere and most parts stores can test them. The DS unit also has a spark timing retard circuit that makes for easier hot starts.
Duraspark will fit your bill well. Make sure you do get a GOOD system. I mean system as in everything, especially on wiring and the ignition module. Replace/rebuild any faulty component and it should give you years and miles of trouble-free system.
I think you'd be better off putting in a Pertronix System, for less than 100.00 you'll have a points-less system. The real big advantage to Pertronix is if it ever fails you just pull out your spare points from the glove box , put them in and off you go. The other systems like Duraspark would leave you stranded. Granted, they rarely go up but you did say you wanted to camperize it. My electonic ignition failed on my 91 F150 leaving me stranded, luckily I was in my driveway!
I have had good luck with the pertronix system. It is by far the easiest way to go. The Duraspark is also a great ignition system!, and if you have the time, and the parts, I believe to be superior to the pertronix setup. Jermafenser, if you can't find an FE duraspark distributor, you can get the duraspark setup from other engines also, it isn't quite as easy though. I had a duraspark setup from a 351M on my 428 (with a '73 390 distributor.) You basically have to take all the "guts" out of the donor distributor, and interchange them with the parts from the points distributor. If you do this, just be sure you get all the advance springs and weights so that the distributor mechanical advance is correct. I used the small cap with success, but if I were to do it again, I would use the large cap that I grabbed from the 351M.
Hi, Does anyone have any suggestions as to how I could upgrade my point type ignition system to an electronic ignition.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
I also run the Pertronix with the Flamethrower coil. It utilizes the stock points distributor so it looks factory. With the Flamethrower coil, I have my EFI type plugs gapped at .050, rather than the .034 factory setting, so it burns much more effeiciently. Another cheap alternative, is the Duraspark distributor coupled with a GM module, with a ford TFI coil. This setup works great, and is easy to install. See the attachment for a description of this set-up.
To avoid being stranded just keep another tested junkyard ignition module under the seat. Depending on the yard and how good a customer you are the cost of a junkyard module will vary. I usually don't spend more than a buck or two. Testing is usually free at your favorite store but just remember all testing machines are not equal. All electronic ignitions can fail but their performance makes up for it. A module is much faster and easier to plug into the harness than it is to install points, no tools required.
I went with the MSD Ready run Dizzy. 3 wires to wire up and a coil. No box needed and after I trouble shot which what I tought to be a crappy Ignition setup was really just me letting a friend tell me that he flushed the old fuel lines of rotten gas......stupid. But after that its all good to go. Looks clean too, 1 less harness and set of plugs to foul up (break the holding clips). Its an idea though. I will throw a pick up when I get off of work.
