Alternator?
Old Feb 4, 2013 | 05:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Not sure how you can get 5.9 volts... There are 3 scenarios:
Standing voltage... Which is usually 12.6 volts
Charging which would be 12.6+ volts
And battery drain which likely wouldn't get much below 10 volts with everything running, even with no output from the alternator
5.9 volts with the engine running means your DMM is fubar'd
Josh
Old Feb 4, 2013 | 08:34 PM
Yahiko's Avatar
Yahiko
Or it's on AC not DC.
Doing that can get you really strange readings.
Sean
Old Feb 4, 2013 | 08:42 PM
MrFixitND's Avatar
MrFixitND
Sean
+1 to that! You could easily get a weird reading that way...
Were you testing from battery negative to the positive post on the alternator to get that reading? Or were you checking the voltage on one of the little wires in the multi-wire plug?
If you were really only getting 5.9v across ground and the alternator output (Big wire), you probably have a bad alt AND bad wiring to the battery... Or a bad ground from the battery to the engine block...
Andrew B.
Old Feb 5, 2013 | 01:39 PM
1badcj8's Avatar
1badcj8
Nope 100% DC from the Alt positive to ground on the body!!!
Old Feb 5, 2013 | 02:06 PM
mustang_309's Avatar
mustang_309
<p>Why wouldn't you go to the negative post on the battery? I would expect you would see system voltage measuring the charge wire from the alternator because it connects to the positive cable on the battery. Unless you had the charge wire disconnected from the alternator when you tested it.</p>
Old Feb 5, 2013 | 03:50 PM
69cj's Avatar
69cj
If he's seeing 5.9v. from the pos. battery terminal to chasis ground I'd be looking for bad ground connections.
Old Feb 5, 2013 | 04:49 PM
Misky6.0's Avatar
Misky6.0
Maybe chaffed wires on steering wheel/column?
Sounds like key was switched to off "momentarily.
Wouldn't engine and lights keep running even
if you unplug battery(s)?
I have also had a bad cell which would cause my
tahoe to stall and dash lightstemp to go out. It would jump
start and idle as soon as i put it in gear and stepped on the gas engine would die.
Had it towed, new battery and alternator.
Shop believed bad battery killed alternator.
Old Feb 20, 2013 | 11:04 PM
1badcj8's Avatar
1badcj8
Thought I'd give a follow up...
I bought a type 6G large case 135amp Alternator and had it installed by a co-worker with that also has a shop. He tested my old one as well and came up with basically the same reading that I got only he got 5.7 volts so yes you can get a reading that low, I knew I was not doing it wrong...
Any way, he also checked everything else we have discussed here and all was good. After installing the Alt everything is working great and it runs all electronics perfect. For my own piece of mind I put my volt meter on it when I got home and it reads 14.4 testing it exactly how I did before.
All is good again in Super Duty town...lol
Old Feb 21, 2013 | 02:21 AM
Yahiko's Avatar
Yahiko
Good to hear you got things fixed.
Sean
Old Feb 21, 2013 | 05:40 AM
mustang_309
Glad you got her whipped.
Old Feb 21, 2013 | 10:47 PM
pile_53574's Avatar
pile_53574
So with the 135 Amp, you are charging 14+ Volts at idle?? With the wimpy 110 amp I get ~13.4 to 13.7. If so that makes my decision easy, gettin a 135 for ~ $160!!
Old Feb 21, 2013 | 11:12 PM
1badcj8's Avatar
1badcj8
I got mine here 6G Series High Output Alternator with Extra Heavy Duty Components for $189 made in the US of A. And as I mentioned its the large case style that were on the 7.3L strokes... Yep for about $40 or so more you can get more amps but I think the 135 is plenty for what I run, which is stock.
Old Feb 21, 2013 | 11:16 PM
  #28
Bullitt390's Avatar
Bullitt390
94-97 7.3 powerstrokes used the large case 3G
99-07 7.3 and 6.0 are small case 6G. Some ambulance packages, snow plow and other dual alt setups used the large case 6G
Josh
Old Feb 21, 2013 | 11:31 PM
  #29
1badcj8's Avatar
1badcj8
Yep I know but these folks make a replacement 6G large case for our single Alt non-ambulance 6.0's...
Old Feb 23, 2013 | 11:03 AM
  #30
mhoefer's Avatar
mhoefer
I am running the stock 140 amp in my 2005 and I get 14.4 or 14.8 volts at the charge cable. If this puppy ever dies I am looking for a 180 to 200 depending on what I can afford.
