Oil change interval
Old Jan 31, 2013 | 08:44 AM
Lastwagen's Avatar
Lastwagen
Well my engine service light is a Code P2043. Some temp sensor I think.
Old Jan 31, 2013 | 10:46 AM
kper05's Avatar
kper05
Yep.
P2043 - Reductant Temperature Sensor Circuit Range/Performance
Old Jan 31, 2013 | 11:38 AM
Lastwagen's Avatar
Lastwagen
Originally Posted by kper05
Yep.
Is this a trip to the Dealer or can it clear up on it's own? I might let it go through a couple regens to see what happens.
Old Jan 31, 2013 | 06:28 PM
kper05's Avatar
kper05
Since I don't know exactly what is wrong and you have a CEL, I would visit the dealer if it were my truck.
No, your truck isn't going to self-destruct but it needs to be corrected.
That code doesn't have anything to do with regeneration.
The reductant tank (and involved sensors) have to do with DEF which is a different part of the SCR system.
Old Feb 1, 2013 | 07:13 AM
Lastwagen's Avatar
Lastwagen
It just seemed that it cut the last regen short. Stopped at 1.48 instead of burning down to the normal 1.15-1.30 soot level.
Old Feb 1, 2013 | 06:55 PM
kper05's Avatar
kper05
I used to burn down to under 1.20 most of the time for two years prior to the latest flash but now I rarely burn down to 1.30 on idential drives.
Mine usually turns off in the upper 1.40's now.
Remaining heat depending on speed can take me to the 1.30's.
Old Feb 2, 2013 | 07:37 AM
Lastwagen's Avatar
Lastwagen
Yep I've noticed that once the red light turns off the EGT1 & EGT2 start to drop but EGT 3 & 4 stay at 1000 or over. I'm assuming there is still some glowing embers burning out the remaing soot. Kind of like a chimney fire I suppose.
mutantsquirl
Jul 20, 2019 11:04 PM
Vinford
6.7L Power Stroke Diesel
Dec 8, 2017 05:59 PM
ruskeigunlover
2009 - 2014 F150
Feb 19, 2013 10:44 AM
RL201
2009 - 2014 F150
Feb 5, 2011 09:20 AM
davelim
2009 - 2014 F150
Sep 19, 2010 07:59 PM
