1978 - 1996 Big Bronco
460 in a bronco
Old May 29, 2003 | 02:11 AM
fordman_in_nv's Avatar
fordman_in_nv
460 in a bronco
I wanted to know some information about the fuel injected 460s.
where there any changes to them? Any particular year that I should look for? I know that in 94 the 351 started using the roller cam, is there a year of 460 with a roller cam? The reason I ask is because I am planning on replacing my tired old windsor with a 460. I'm sure alot of you think that is a stupid idea, including my dad, but when you are 17 those are the only kind you get. If any one has done this swap or knows what else besides the tranny need to come out with the 351 that info would be great.
Old May 29, 2003 | 09:32 AM
mrwizard's Avatar
mrwizard
460 in a bronco
Besides all the engine components you will need, you will probably need to upgrade the front springs as well. The 460's are heavier than the small blocks, and would really make the front end sag.
Old May 29, 2003 | 10:33 AM
dsickles's Avatar
dsickles
460 in a bronco
A 460 is 720lbs and a 351W is 510lbs
Old May 29, 2003 | 10:52 AM
Broncomule's Avatar
Broncomule
460 in a bronco
I had a 460 installed in my 88 Bronco . As far as brute torque & horsepower it excelled. Handling was a much different scenario. Even with new front springs and four new shocks on the front a sharp curve was not its favorite place to be. On a straight stretch towing anything I cared to tow it was a hoss. One trip into the North Carolina mountains and I sold it . Bought the 86 I have now with 351w HO and have really enjoyed the much better handling.
Old May 29, 2003 | 11:52 AM
bigric's Avatar
bigric
460 in a bronco
Since you'll be changing to a C6 transmission, you may find that it is of a different length than your E40D and some other mods may need to be made.
In addition to just the engine and transmission, you will need to get the computer from the donor vehicle. This isn't a terribly straightforward swap; expect some effort and money on your part. The motor mounts will also need to be changed. Keep in mind what Broncomule said; your handling characteristics will be much different.
If you are dying to spend money for performance, you can get some pretty good performance out of that 351W for less money than you may spend on the 460. The 460 is a fun engine, but the swap will probably be more than a "weekend fun project" unless you've got a well-equipped shop and you are into fabrication.
What year is your current Bronco?
Old May 29, 2003 | 04:23 PM
alanscott's Avatar
alanscott
460 in a bronco
I shoved a carbed 460 into a quad shocked '83, and I would do it again. The handling is a little different but not enough that I even think about it anymore.
The original springs have been holding up just fine for the last 5 years. I started to get a little sag not too long ago, but that turned out to be the axle pivot bushings needing replaced.
The motor mounts wasn't that big of a deal. I did a little measuring, then cut the 351 mounts and the 460 mounts apart, then welding them together. I guess you can buy motor mount kits but I have never looked into them.
You will need to relocate the oil filter with a remote kit, there is not enough room in the original location.
Old May 29, 2003 | 05:37 PM
fordman_in_nv
460 in a bronco
My bronco is a 88, and it has a c-6 so I was planning on swaping a e4od in with the 460. I had also thought of building a stroked windsor but money is tight. So everyones opinion is welcome tell me wich you think would be better.
Old May 29, 2003 | 05:47 PM
bearfoot_25's Avatar
bearfoot_25
460 in a bronco
i say stroke the windsor and get a set of cleveland heads to put on it, that'll put that 460 to shame!!!!!!
Old May 30, 2003 | 10:51 AM
Kemicalburns's Avatar
Kemicalburns
460 in a bronco
you will spend more money and time going with the 460. the 351 is a good motor and can be built well for less then this swap you are thinking about doing. but either way good luck and do things right the first time.
later
Old May 30, 2003 | 05:10 PM
fordman_in_nv
460 in a bronco
Thanks for all the advice I think I'm going with the 351 because it will be eazier,lighter and more fuel eficent. Thanks for all your help.
Old May 31, 2003 | 08:58 AM
georgedavila's Avatar
georgedavila
460 in a bronco
I've been running 429/460s in an '82 Bronco since 1986. It's a pretty simple swap and the extra 200 lbs has no adverse affect on handling, not the Bronco's strong suit to begin with. After using both the 351 and 460 engines, I wouldn't even consider going back to a 351W.
http://www.angelfire.com/realm3/george_d/index.html
mvvette97
Jan 8, 2015 12:26 AM
85lebaront2
Mar 12, 2014 05:51 PM
6978sghfbjklgdfsjhkl
15
Jan 25, 2014 06:58 PM
Davie J.
Jan 1, 2014 07:38 PM
bradleyj
13
Apr 9, 2003 06:47 AM
