Squeek from left front?
Old Jan 28, 2013 | 08:25 PM
JWink's Avatar
JWink
I'm trying to id a noise that is making me very nervous...
When in 4x4, switched from the dash and when locked as well there is a squeek that sounds like it is coming from the left front. I would explain it as a rotational noise. When in the cab it still sounds like a deep hum. Kill the 4x4 and the noise stops.
This summer I serviced the hubs; bearings through the abs sensor, needle bearings and serviced the lockouts. Ujoints on rear driveshafts and carrier bearing replaced, shaft balanced (shouldn't matter as it only happens in 4x4.
How can I isolate the source? I assume it must be axle or diff related. If I was to drop the main drive shaftand jack up the front end (on stands of course) would engauging the 4x4 be asking for problems?
Thanks,
Wink
Old Jan 28, 2013 | 08:59 PM
4inchlovin's Avatar
4inchlovin
I would start by jacking up the front end of the truck get both front tires off the groud put it in 4x4 and spin the front tire by hand and see if you can hear where it is coming from...
Old Jan 29, 2013 | 06:31 PM
JWink's Avatar
JWink
Thanks Nolan! I got it up on stands this am and was able to isolate it to the front driveshaft. After dropping the shaft it was in the CV joint. So off to see the folks at Rocky Mountain Driveline and it should be ready tomorrow. Not cheap but it will be good to know it won't come apart when 4wd is needed!
Wink
Old Jan 29, 2013 | 07:05 PM
4inchlovin's Avatar
4inchlovin
Thanks for the update glad you got it figured out.
JayP63
1997 - 2003 F150
Mar 15, 2018 06:47 PM
Armyrules2
Jan 25, 2018 05:55 AM
Nick8bevill
Jan 9, 2017 08:09 PM
Raise
40
Dec 14, 2014 05:58 PM
dog2580
1997 - 2003 F150
Jan 10, 2012 10:07 AM
