4x4 noise
Old Jan 24, 2018 | 02:44 PM
Armyrules2's Avatar
Armyrules2
4x4 noise
I have a 1996 f150 xlt 4x4. So I just had my transmission rebuilt. And when I got the truck back I wanted to check and make sure my 4 wheel was working. When I put the truck in 4 wheel high and accelerate quickly I sometimes hear a scrapping or grinding noise coming from the front passenger side of the truck. Keep in mind I have manual warn locking hubs. But when I put it low range it doesn't do it. And it also doesn't do it all of the time. My 4 wheel is working though because if I gun it I'll spin the tires in the mud.
Old Jan 24, 2018 | 02:47 PM
Skip1970's Avatar
Skip1970
maybe its that center ujoint on the front ttb
Old Jan 24, 2018 | 02:49 PM
Armyrules2's Avatar
Armyrules2
The u-joint on the drive shaft? Or the bearing that's in between the two halves of the ttb?
Old Jan 24, 2018 | 03:12 PM
Skip1970's Avatar
Skip1970
2 halves is what i would shoot for
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Armyrules2
....Or the bearing that's in between the two halves of the ttb?
What bearing are you talking about?
Old Jan 24, 2018 | 03:13 PM
skuzzybucket's Avatar
skuzzybucket
Could be a hub not completely locking too
Old Jan 24, 2018 | 03:14 PM
Armyrules2's Avatar
Armyrules2
What's in between the two halves of the axle?
Old Jan 24, 2018 | 03:15 PM
Armyrules2's Avatar
Armyrules2
How could I test that because that's what I'm thinking it is.
Old Jan 24, 2018 | 03:18 PM
Skip1970's Avatar
Skip1970
crawl under it and yank the heck out of it with your hand youll know if that ujoints bad
Old Jan 24, 2018 | 04:39 PM
skuzzybucket
To test hubs
1)lock right hub
2)turn front drive shaft by hand until it stops turning. if it don't stop, right hub is bad
3)Unlock right hub, turn drive shaft till free
4)lock left hub
5) turn front drive shaft until it locks. if it don't lock hub is bad
6) unlock hub
Hubs make an ungodly noise when they aren't locked all the way. Plastic eating itself up is hard on the ears
Skip is right about the axle bearing in the long axle ,look for oil running out of the seal there where the axle comes out for a tell tale sign too
Old Jan 24, 2018 | 04:53 PM
Skip1970's Avatar
Skip1970
i didnt mean axle bearing i meant ujoint in center of ttb, its actually a bearing too needle bearings in the caps. but i just miss typed and said bearing instead of ujoint.
Old Jan 24, 2018 | 06:16 PM
skuzzybucket
96 has a bearing in there skip
It changed in 92
Old Jan 25, 2018 | 05:55 AM
joegeds's Avatar
joegeds
This might help (from the '96 service manual):
FlaresideF150
Jan 8, 2014 01:54 AM
af11
Offroad & 4x4
Jan 15, 2011 05:20 AM
BostonX73
Mar 16, 2010 11:36 PM
cletus_the_red
Aug 21, 2007 05:30 PM
Will_01_GT
1978 - 1996 Big Bronco
Dec 21, 2004 03:57 PM
