Sponsored by: Real Truck
Front end question
Old Nov 30, 2014 | 07:56 AM
Long Haul's Avatar
Long Haul
Front end question
Looks like I've aquired all the parts for a front end rebuild..
Problem is the weather here sucks now and I don't have a garage this is a driveway deal..
I'd rather not do the ball joints until the weather improves and I have more time.
If I replace everything else, but not do the ball joints until spring, would the wore out ball joints cause the tie rod ends and sway links to wear too soon ??
or should I wait and do it all at once ??
Old Nov 30, 2014 | 10:00 AM
Snowseeker's Avatar
Snowseeker
The worn ball joints won't cause the tie rod ends to wear any faster. Personally if the tie rods aren't to the point where they are unsafe I would try to wait to do it all at one time. Its not to big of deal but there is a risk that you will tear the tie rod boots when pulling it apart the second time for ball joints.
Now if the tie rod ends are slopped out pretty good I would maybe change out all the steering stuff now just for the safety aspect of it. Bad things happen when a tie rod end falls out of its socket on the highway.
Old Nov 30, 2014 | 10:02 AM
vortec 1's Avatar
vortec 1
Unless there is excessive play in the ball joints, I don't see that it would wear more but I would wait and do it all at once if you can. Your going to have to get the front end realigned when you do the Tie rods and I wouldn't want to tear into it after its aligned JMO.
Old Nov 30, 2014 | 10:48 AM
Long Haul's Avatar
Long Haul
Thanks for the fast replies much appreciated !
Its got the dreaded wander but doesn't feel unsafe thus far...I'll wait and do it all in the spring, might need brakes by then anyway..
Lawnpro979
Dec 5, 2017 11:07 AM
ligito
May 22, 2015 05:54 PM
Awitte58
Jul 29, 2011 07:14 PM
Duke78
Jan 12, 2009 03:19 AM
shenders99
Nov 27, 2006 03:51 AM
