Ignition issues
Old Jan 27, 2013 | 09:36 PM
fordwarden's Avatar
fordwarden
Ignition issues
so guys heres a puzzleing one for you...my 1990 f250 7.5 wont turn over.
i get power to the gauges
if i jump the relay the starter turns over
i replaced the ignition modual and the actuator rod hits it good
i replaced the lock cylinder
battery tested good
played with the neutral safety switch
I cant get the dang b*tch to turn over.
ill turn the key and all i hear is a click under the dash board.
any suggestions guys?
fordwarden's Avatar
fordwarden
im totally lost and dont know where to go
Old Jan 27, 2013 | 10:29 PM
88n94's Avatar
88n94
Are you sure your actuator rod isn't broken? If you can get at that skinny rod that goes down to the ignition switch, I would push down hard on it, with the ignition switch on, and see what happens.
Old Jan 28, 2013 | 05:49 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Is your ignition switch adjusted correctly on the column?
You say NSS, so I assume this IS an automatic.
They do go south. Try jumpering it to test.
If it's a manual gearbox perhaps firewall flex is keeping the clutch safety interlock from being depressed?
Old Jan 28, 2013 | 07:39 AM
fordwarden's Avatar
fordwarden
My actuater rod is good. I've manually depressed the ignition module and still no start. It's an automatic c6. I've tied starting it in neutral and I've dropped the column and visually inspected the rod.
Old Jan 28, 2013 | 08:47 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Trying in neutral will only show if the Park contacts are bad.
Jumper the switch entirely, before you go chasing the wiring to the solenoid.
A NSS isn't cheap, but you may find that the connector is just loose or dirty.
Old Jan 28, 2013 | 11:32 AM
fordwarden's Avatar
fordwarden
How do I jump the switch?
Old Jan 28, 2013 | 11:40 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Just have to connect the red/blue wires together.
Do your reverse lights work?
Old Jan 28, 2013 | 12:40 PM
fordwarden's Avatar
fordwarden
Actually no the reverse flood lights only come on if I jiggle the shifter **** on the column..it had a "sweet spot" then they would come on. I'm on 24 hour shift so I'll try crossing the wires tomorow when I'm off. The red and blue wires are the ones on the NSS on the tranny right? Cross those then try to start it with the key?
Old Jan 28, 2013 | 01:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I was just trying to figure if it was completely unplugged.
The AOD has different colors than the C6's I'm used to.
I found this post;
AOD:
1) Black/pink........rev light
2) Pink/orange......rev light
3) Red/blue..........start
4) Orange/white...start
5) Red/white........ECM
Old Jan 28, 2013 | 01:55 PM
fordwarden's Avatar
fordwarden
So cross the start wires?
Old Jan 28, 2013 | 02:25 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
By connecting them together you will confirm or eliminate the NSS as a possibility.
If you find the switch is loose or dirty then it should be simple to fix
Old Jan 28, 2013 | 02:35 PM
fordwarden's Avatar
fordwarden
I'll give it a try tomorow morning and get back to you about it. Thanks for your help!
4BigGreen's Avatar
4BigGreen
Fordwarden, this link is a for a 7.5L but it may help you.
https://www.ford-trucks.com/forums/689200-nss-replacement.html
jump the two wires that the NSS connects to complete the circuit.
Not sure what the wire colors are on your your model. (On the 1990 7.5L it's the white/pink wire and the red/lightBlue blue wire)
Good luck.
Old Jan 28, 2013 | 03:12 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Wait!
In your first post you say 7.5l.
You have a C6, there should only be 4 wires.
I don't know where I got AOD. Eeesh!
I was not looking at the red/blue changing to pink/white at the harness connector.
Thank you BigGreen for the schematic.
conrad10781
13
Nov 27, 2024 04:24 AM
Luko
13
Nov 24, 2017 01:05 PM
JJray
22
Apr 3, 2011 03:28 PM
jrv
May 16, 2008 08:49 PM
Kallie
1978 - 1996 Big Bronco
Jul 1, 2003 03:07 AM
