horn won't work
Old Feb 2, 2013 | 12:55 PM
fmc400's Avatar
fmc400
MSEE
Glad to hear you got it worked out.
Old Feb 2, 2013 | 02:37 PM
V10man's Avatar
V10man
My horn pad is trashed so I removed it for the time being. I have cruise controll. Is the horn relay on the pass fender above the starter selenoid? Two yellow thicker wires with a smaller blue wire or where would it be with CC? I have 2 wire conectors in the wheel. One is a short piece of black wire with a female bullet conector and the other is just a flat spade. I jumped the spade to the center shaft and got nothing. I think the bullet conector was for the cruise. You dont realize how much you use the horn until you dont have one.
Old Feb 2, 2013 | 03:04 PM
F350moneypit's Avatar
F350moneypit
Do truck horns have a different tone than a car horn?
Right now my truck horn (not sure where I got it) sounds more high pitched than the original horns in my '69 mustang.
NUMBERDUMMY; how many different horn part numbers are there from 67-79?
Old Feb 2, 2013 | 04:01 PM
fmc400's Avatar
fmc400
MSEE
The horn in my '79 F100 sounds the exact same as the horn that was in my '77 LTD. The dual-horn setups have separate high and low horns; maybe you're running a single high horn.
Old Feb 4, 2013 | 01:46 AM
privateer, eh's Avatar
privateer, eh
I've got a horn in the shed thats made from 3/8 checker plate and wieghs over 150 lbs. Can be painted to match any color vehicle. Always works.
SuperDuty93
16
Jul 2, 2017 11:17 AM
skidoorulz
Apr 9, 2014 11:03 AM
76F100guy
20
Feb 6, 2009 07:54 PM
Polkat
Sep 15, 2002 04:15 PM
redneckdieselmechanic
Electrical Systems/Wiring
Aug 14, 2002 10:52 AM
