amp meter
Old Jan 27, 2013 | 03:31 PM
sctrt's Avatar
sctrt
Cool amp meter
My amp meter used to give me irratic readings. Now it stays all the way over
to the right. I would like to get it working again. Can anyone tell me what is wrong and how to fix it?
My truck is 1985 f150,fuel injected, 302, automatic.
Thanks for any help.
SCTRT
Old Jan 27, 2013 | 06:19 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Does it do it with the truck off, and not running, or does it only peg to the right when the truck is running?
It could be something as simple as a bad gauge, to something as complex as the wire from the alternator to the battery is bad, and most of the charging circut is being bypassed into and through the ammeter. (Not good! could cause fires.)
Old Jan 27, 2013 | 06:57 PM
9wire's Avatar
9wire
Theres a little old lady locally that drives a 66 f series, it was about to go up in flames, the aftermarket amp meter was melting, and the insulation was burning off of the underhood wires. I got the battery cable off before it went up.
Old Jan 27, 2013 | 07:14 PM
81-F-150-Explorer
Yes, that is why the shunt is so important. Do a search here for shunts, I'm sure you will find posts by me explaining the dangers of bypassing or not using the factory shunt. Or for that matter using a aftermarket ammeter without installing the needed shunt.
zemus420
Jan 17, 2006 08:11 AM
th0mpson182
Jul 17, 2004 04:16 PM
cntryboy0531
Jun 18, 2004 08:03 PM
downdeephuskyjerk
Electrical Systems/Wiring
Nov 9, 2003 07:02 PM
BlueTorpedo85
Feb 9, 2003 08:36 PM
