Sponsored by: Innova
car dying
Old Jul 16, 2004 | 05:30 PM
th0mpson182's Avatar
th0mpson182
car dying
ok, I have an optima battery, 200 amp alternator, brand new negative cables grounded 2x to the body, and a new positive terminal, and I still have problems with power... i run 2 m3 12's on a memphis 1100D amp. It's bridged to 1 ohm so it's 1100 W RMS and it's real 1100 not some lanzar amp or something so its a lot of power.why does my still go dead sometimes and just be weird? Also, 2 more questions... Why is it important your negative wire be as short as possible? and should I run 2 gauge instead of 4 off the battery? I am running this amp and im going to run another memphis doo rspeajer amp 115w x4 rms
Old Jul 16, 2004 | 05:50 PM
kens64's Avatar
kens64
Probably a bad connection somewhere. Recheck all your connections, especially your grounds, scrape any paint off the metal your grounding to. Or try a different ground point. Your grounds should be at least as big as your power cables. What gauge are you using for your alternator, ground, and power?
Old Jul 16, 2004 | 05:52 PM
th0mpson182
using 4 guage I beleive.
Old Jul 16, 2004 | 05:58 PM
kens64's Avatar
kens64
That should be fine. Recheck all your connections starting at the battery if your car is dying. It only takes one to mess everything up.
Old Jul 17, 2004 | 09:07 AM
th0mpson182
I beleive it is actually an issue with the solenoid, i messed with a wire on it and the car started right up.... power loss wasn't really the issue it seems like
Old Jul 17, 2004 | 04:16 PM
kens64's Avatar
kens64
Glad you got the problem fixed
