Battery saving?
Old Jan 27, 2013 | 02:33 PM
maytag906's Avatar
maytag906
Battery saving?
My 2011 F 150, when I shut it down, would continue to play the radio for a few minutes, until I opened the door.
Now, the radio plays for a few seconds, and a message "BATTERY SAVING MODE or similar appears in the radio. What changed?
Old Jan 27, 2013 | 03:22 PM
svt2205's Avatar
svt2205
It's shutting the systems down because you have a low/weak battery. It's part of the battery management system. This is described in your owners manual.
I would get your battery checked and keep a set of jumper cables in your truck, just in case.
Old Jan 31, 2013 | 04:56 PM
maytag906's Avatar
maytag906
Thanks. I really need to drive this thing more, I only drive it a few times a month. Drove it 40 miles back and forth to work, problem solved!
Old Feb 1, 2013 | 01:06 PM
svt2205's Avatar
svt2205
Yup, driving it more will certainly help. But if you're going to only drive it a couple of times a month, you might want to pick up a battery tender charger and maintain the battery that way. Worth looking into.
Old Feb 1, 2013 | 01:15 PM
tspangle84's Avatar
tspangle84
I drive mine every day and I still get that warning more than half the time. Even after a long drive. I'm thinking I either have a drain somewhere or the sensor is faulty. Either way I should probably take it in.
Old Feb 5, 2013 | 04:31 PM
Toto's Avatar
Toto
Go buy a Battery Tender...they are about 30 bucks and will float a charge without overcharging. I have one on my bike and my trailer battery.
You can get 'em at a bike/atv place.
Even come with a quick plug connector that you can hang out the underside of your hood.
You don't need a biggy as they are not used to quick charge a battery.
P.S.
Jeeze..sorry ST..I guess I should have read more carefully....
dirttoo
2009 - 2014 F150
15
Apr 18, 2017 09:11 AM
AzPete
2009 - 2014 F150
Apr 8, 2016 08:36 PM
9rudy9
Electrical Systems/Wiring
Feb 4, 2016 10:16 AM
Jaime74656
Mar 23, 2013 03:45 PM
Rancheroracer
2004 - 2008 F150
Feb 12, 2008 11:02 PM
