Engine perch question
Old Jan 27, 2013 | 12:30 PM
mdlave's Avatar
mdlave
I'm in the process of installing motor mounts for a 460 swap into a 1978 Ford F150. It looks like the previous owner, in a failed attempt to use some preexisting motor mounts, drilled/cut another hole in the face of the engine perch. It is approximately the same size as the original hole, and leaves about 1/4" of material in between the two holes.
My plan is to find a set of replacement perches and install them eventually, but I want to be able to drive the truck prior to that. The engine is otherwise stock, and I'll monitor the stress and take it easy.
Will the second hole make the mount too structurally unsound, or am I being paranoid?
Old Jan 27, 2013 | 12:45 PM
jim collins's Avatar
jim collins
With out a picture I am just guessing what it looks like . So, maybe a large washer on the underside or weld a plate in and drill new holes. Should be okay for a short time ,but I would replace them as soon as you start driving it a lot. Hope that helps. JIM
Old Feb 1, 2013 | 08:52 AM
mdlave's Avatar
mdlave
I've attached a photo to show the mount situation. The same amount of material is removed from the engine perch on the other side.
In addition, I haven't been able to loosen/remove the third (lower, towards the front of the vehicle) bolt from the old motor mount to remove it. The top two eventually loosened with quite a bit of PB Breakfree. I'm not even quite sure how to get to it. Any suggestions?
Old Feb 1, 2013 | 07:00 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2WD or 4WD?
Please, when asking questions, list all the pertinent info.
4WD: 460's weren't available with 4WD until 1983. These parts will not work. You'll have to buy an aftermarket engine mount kit and a reverse sump pan, pickup tube and stud that attaches tube to the crank journal.
2WD: Find a 1973/79 F100/350 460 and get the following:
D3TZ-6028-A Right & D3TZ-6029-A Left .. Engine Supports aka towers, stands, perches.
D3TZ-6030-A Right & D3TZ-6031-A Left .. Brackets-These bolt to the block, the rubber insulators bolt to these, then to the supports.
2) D3TZ-6038-A .. Right/Left Front Rubber Insulators.
D3TZ-6A023-A .. Rear Engine Support, aka crossmember, bolts on / Same as 1973/76 F100/250 2WD & F350 360/390.
D3TZ-6068-C .. Rear Engine Rubber Insulator.
Old Feb 1, 2013 | 10:32 PM
jim collins
I am assuming this is a 2 wheel drive truck because you say you are going to find the replacement perches for the 460 ? You don't say so but you won't find factory ones for a 78 / 4x4 as it's been pointed out.
You can weld the holes shut and punch in new holes , but if it's just for a short time , then put a big washer there . But that is not a fix for the problem . I would just start looking for some replacements ,those may not have the engine at the right height . When i did a 79 F-100 2 wheel drive about three years ago I used some from a 79 F-150 super cab 2 wheel drive that i had as a work truck and scraped out.
Baer
WTB - Parts & other
Oct 22, 2016 08:55 AM
norvillebob
Jul 7, 2016 01:37 PM
Second79F250
Apr 27, 2012 10:56 PM
zakt
WTB - Parts & other
Jun 1, 2010 09:36 PM
DeVicEofHeLL
Mar 15, 2010 04:41 AM
