Technical Questions on the Mini Maxx
Old Jan 27, 2013 | 11:21 AM
frdf250's Avatar
frdf250
1) I know dodge has a section in the install sheet about high idle....do we have any options with that? From my understand the way it works with the dodge is when you put it in park and set the e brake it will idle up to your preset RPM (700-1400~)...
2) My other question is how long will the mini max hold the tune if you take it out. I know it will reset to stock after a while but how long is "a while"
3)If I install the mini max and just leave the dpf present setting on, basically just mount it in the truck to have it to look at will that log into my pcm and void possible warranty claims if i go to take it to the ford dealership? I was hoping not since i will still log regens
4) One last question...when they talk about head unit in the instructions do they mean your radio head unit or your mini maxx head unit.
sorry for all the questions im just getting ancy here. Have this thing sitting on the shelf at home for 2 months now. only have 10k on the truck but thinking about installing it soon....
Old Jan 27, 2013 | 11:43 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Hey Phillip, I don't have the answer for you but here is a recent write up from Savage that is very good and maybe will answer some of your questions.
https://www.ford-trucks.com/forums/1...x-install.html
Old Jan 27, 2013 | 11:49 AM
frdf250's Avatar
frdf250
thanks Tim, i actually just read that before i posted up. that is a good write up thanks for including it. Hopefully someone will comment soon, figured this would be good for everyone to know since im sure more and more questions like this will come up as the trucks get older.
Old Jan 27, 2013 | 01:24 PM
Andrew010's Avatar
Andrew010
No high idle through mini maxx for Ford trucks.
Mini maxx defaults to 'no power' setting when unit is not plug in. It's an instant change as soon as unit is unplugged.
Once the mini maxx is installed ( dpf on or off) the same info will be stored on the trucks computer which gives Ford everything they need to deny warranty claims on anything effected by the tuner. Basically, download the tune and give up warranty. Not saying you can't sneak something by the service dept if the tech wasn't looking for the tuner.
No clue on the 'head unit' question. I didn't read/use the directions for installation. It was pretty straightforward how to install it so I never read the book.
Old Jan 27, 2013 | 02:52 PM
frdf250's Avatar
frdf250
ok so thats what i thought......
once i unplug the unit it will go to no power...does it still save the dpf delete stuff? in other words if i needed to let someone use my truck i could just yank the mini maxx out and it would just go to no power dpf not present setting?
thanks for your help man i really appreciate it
Old Jan 27, 2013 | 02:55 PM
Andrew010's Avatar
Andrew010
Yes, it would go to no power dpf off.
Old Jan 27, 2013 | 08:46 PM
OffroadSD's Avatar
OffroadSD
Philip, I had mine sitting on my desk since November 1st. I am getting ready to turn 40K on my truck. I installed mine this weekend and "Wow" is all I have to say. The truck is so responsive now and shifting is quick and smooth.
Hopefully there are no regrets from this install.
Old Jan 27, 2013 | 08:48 PM
Andrew010's Avatar
Andrew010
The only downside I see is rear tires.
Old Jan 28, 2013 | 10:45 AM
bama29fan's Avatar
bama29fan
Phillip, you know you will have to put that "Tuned" truck on the track at RRe this year.
Old Jan 28, 2013 | 12:38 PM
Tomahawk's Avatar
Tomahawk
Phillip - Re: Question 1)
High idle mod. is easy once you locate the wires under the far left side of the dash.
This thread describes the mod. Good Luck.
https://www.ford-trucks.com/forums/1...ml#post9494561
Old Jan 28, 2013 | 07:25 PM
frdf250's Avatar
frdf250
i guess ill wait a little more..
and thanks for the mod link. i am going to add that to aux 1 switch. thanks for the help man!
BillyBob69
2015 - 2020 F150
Feb 28, 2019 10:10 AM
14psd
Jul 10, 2006 02:10 PM
BlauLicht
1997 - 2003 F150
Mar 24, 2006 12:32 AM
tstem
Jun 15, 2004 03:27 PM
