Fuel Pump Replacement - HELP
Old Jan 26, 2013 | 03:32 PM
01texaslonestar's Avatar
01texaslonestar
I have a 1997 F350 7.3. I am replacing the fuel pump. In researching i have followed other write ups about the procedure. I have the fuel canister unbolted the hoses off the top of the pump and have the connector off of the bottom hose. I have not gotten the hose off the bottom yet.
The fuel pump is unbolted and lose, it wiggles, but I can not get it out. Some wrote about turning the engine over by hand and the cam would push the pump up and keep the tappet from falling out.
Question: how do you turn the enging by hand?
Any trade secrets on getting the pump out?
Thanks - Rick
Old Jan 26, 2013 | 04:17 PM
fordman67's Avatar
fordman67
Watch it with the bolts loose and have a buddy just bump the starter over a bit at a time till it pops up.or get a big braker bar and socket and turn the balancer by the bolt.
Old Jan 26, 2013 | 05:12 PM
Action4478's Avatar
Action4478
Clock the motor with the mark on the balancer to the pointer on the CPS . That makes it impossible to loose the tappet ..The pump won't pop up out of the engine , it designed not to .. Bolts out turn it back & forth as you pry on both of the bolt tabs simultaneously . If it breaks off , the tappet will still be there to attach a puller to ...
Old Jan 26, 2013 | 05:24 PM
fordman67's Avatar
fordman67
I thought somebody said it would.I never worry,but have not had a problem with the tappet honestly.
Old Jan 26, 2013 | 05:25 PM
fordman67's Avatar
fordman67
My phone is sfupod and reposts my stupidity...
Old Jan 26, 2013 | 05:45 PM
Action4478's Avatar
Action4478
It shouldn't buddy . The stroke of the tappet is limited to the distance it travels when the pump is bolted down ..If the OP can't pull it out , the tappet won't push it out ...
Old Jan 26, 2013 | 06:23 PM
fordpride's Avatar
fordpride
Did you take the banjo bolt out of the back of the fuel pump connected to the metal fuel lines ?
Old Jan 26, 2013 | 07:27 PM
01texaslonestar
Thanks. Got the pump out and the new one back in before dark. That banjo bolt on the back is something else. Took a while to get it started correctly.
In the morning I will get the other lines hooked back up and give it a test.
While i was under the hood, I took a look in the fuel canister, it appears that the heating element is broken. (the round disk wire loop with the electricial connection).
Does anyone have a part number for this?
Will the the truck still work with this disconnected?
-Rick
Old Jan 26, 2013 | 09:45 PM
MagKarl's Avatar
MagKarl
Yes, it will run fine with the fuel bowl heater disconnected. Mine is unplugged on the inside and the wires stripped from the disk. Been that way for years. I don't know if it makes a difference or not but I left the disk in there so the standpipe would still be in the same place. I think the standpipe is LH threads if I remember right.
armymanfo
22
Jul 28, 2020 11:36 AM
matowns21
Dec 7, 2011 06:54 PM
skidford
18
Nov 22, 2007 08:28 AM
Dstosh
Sep 8, 2007 07:24 PM
whiteschoolbus
Jan 24, 2007 10:52 PM
