2 tubes
Old Jan 26, 2013 | 07:53 PM
m-chan68's Avatar
m-chan68
Originally Posted by DieselVol
Yes, I'm running 75 mph now and it's running 26-31. I doubt I've had a re flash since 2004.
....... which is quite possible if you are indeed the original owner and haven't had it reflashed by either a dealer or someone with an IDS scan tool.
Old Jan 26, 2013 | 08:00 PM
DieselVol's Avatar
DieselVol
I ordered it personally in '02, before the first 6.0 ever hit the road, so at least I can't be blamed for buying one of those crappy 6 liters. They were still the best engine ever when I ordered mine! In the early days, we all refused to be RE flashed since it was obvious that Ford was just guessing. Are my numbers normal?
Old Jan 26, 2013 | 10:25 PM
bismic's Avatar
bismic
The numbers should be within 0.5 psi at KOEO, so you are probably close enough.
Old Jan 26, 2013 | 11:04 PM
DieselVol's Avatar
DieselVol
Anything to expect to change about the numbers while it actually having the turbo problem? Currently, it runs fine on cruise at highway speeds. It's just getting there that's a problem.
Old Jan 26, 2013 | 11:10 PM
bismic's Avatar
bismic
It is possible the EBP sensor could be off by more than the prescribed amount at higher values, but it most likely is fine. Sounds like maybe a turbo cleaning could help. has that ever been done?
Old Jan 27, 2013 | 07:40 AM
DieselVol's Avatar
DieselVol
Yes, about 3.5 years ago. I've got to believe it something he did or didn't do, since it was not a problem when I took it in, and I noticed the problem in the first 100 yds I drove it when I picked it up.
Old Jan 27, 2013 | 03:35 PM
DieselVol's Avatar
DieselVol
Both the MAP and EBP remain steady while the turbo is running through these cycles. Not sure what the deal is.
Old Jan 29, 2013 | 04:47 PM
DieselVol's Avatar
DieselVol
My mechanic has started watching my ScanGauge. He reports that when you push the truck hard, the MAP will go to 32. If you stay on it, it will drop to 1. Since KOEO is 14.4, I'm thinking that has some significance. Does it?
Old Jan 29, 2013 | 05:24 PM
bismic's Avatar
bismic
MAP should never drop below atmospheric pressure (14.4 for you it sounds like).
Old Jan 29, 2013 | 05:27 PM
DieselVol's Avatar
DieselVol
Hmmm...bad MAP sensor, or at least not hooked up right?
Old Jan 29, 2013 | 05:32 PM
bismic's Avatar
bismic
That is what I would say. Might look at all the wiring to rule out chaffing of the wire/harness.
Old Jan 29, 2013 | 05:36 PM
DieselVol's Avatar
DieselVol
Thanks. He's looking into that now. He now, at least, agrees that it is happening. I got one of those, "we drove it and no problems" calls. I told him how to make it do it, and got the "sorry, missed it" call later.
Old Jan 31, 2013 | 08:54 PM
  #28
DieselVol's Avatar
DieselVol
How the story ends:
I spoke with Andrew from Bulletproof Diesel's own shop. He also recommended checking out the "2 tubes" we all discussed before. Additionally, he suggested doing a "VGT relearn" and even forwarded me an email on how to do it. That fixed it. Runs like a top now. Thanks to all for the help.
dan9812
Oct 12, 2016 01:13 PM
sandman1984
May 19, 2015 09:19 PM
cbebuck
Aug 2, 2011 01:10 AM
strateman
Apr 20, 2009 11:21 AM
misterc
Mar 8, 2008 02:05 PM
