Confused
Old Jan 26, 2013 | 09:19 AM
Regulator1988's Avatar
Regulator1988
Exclamation Confused
I just removed my EGR valve due to a p0299 egr code just to see what was going on and the Orings for the valve was pretty shot, I went a head a put a brand new valve in it for 150 bucks lifetime warrenty. But when I looked in the manifold it was wet in there. With a BFD egr cooler delete how would coolent get in there?
Old Jan 26, 2013 | 10:31 AM
cheezit's Avatar
cheezit
you can tell the difference between coolant, unburned fuel or oil? how about condinsation?
Old Jan 26, 2013 | 10:36 AM
Regulator1988
It looked a bit like oil
Old Jan 26, 2013 | 11:33 AM
cheezit's Avatar
cheezit
fuel mixed with carbon looks like oil too
Old Jan 26, 2013 | 11:44 AM
bismic's Avatar
bismic
+1 for it being fuel if it feels greasy to the touch.
Old Jan 26, 2013 | 02:48 PM
Regulator1988
I dont think fuel is supposed to be in there...
Old Jan 26, 2013 | 03:07 PM
bismic's Avatar
bismic
It is common with an EGR system if you have ANY combustion efficiency issues, and most people do. I would MUCH rather see a little fuel in there than coolant .......
Possible contributing factors:
excessive idling
bad FICM or weak system voltage
poor fuel quality
bad EGR valve
poor turbo operation
restricted air flow
bad injector
too many short trips (IMO)
I saw this early on with my truck and resolved it by:
1. minimizing idling and using the high idle when I did want to idle
2. Replaced the EGR valve - Ford updated it in 2007 or so I believe.
3. Added a fuel cetane boost each tank
4. Every so often, made sure I had some WOT runs to blow out carbon, get the temps up, etc.
I also ran my ccv to a filter which I think also helped keep the EGR valve clean and dry.
The sticky solids will eventually cause poor EGR valve operation and accelerate intake fouling.
emmagator
May 25, 2013 09:54 AM
swamp06
Nov 1, 2011 10:21 AM
canucklehead2004
Jul 26, 2010 07:31 AM
builttoughf350
May 31, 2010 02:36 PM
satwood
Feb 21, 2010 09:59 PM
