Racking the old brain here
Old Jan 25, 2013 | 09:32 PM
Ram2500's Avatar
Ram2500
Ok thanks for the info anything helps
Old Jan 25, 2013 | 10:39 PM
52 Merc's Avatar
52 Merc
Originally Posted by Ram2500
what i a doing is trying to connect the outlet side of the radiator to the inlet side of the water pump ( bottom side) Problem is they are opposite of each other. So I thought of using copper pipe to connect the two ends together if that makes any seance cuz I have to run under the balancer to connect the ends. And the bends are tricky and using just hose seems it wants to want to collapse
I did the same thing many years ago when I put a big block radiator in my early Mustang for the hipo 289 I built for it. I didn't want any cooling problems and went way overkill on the rad. I took 2 lower hoses, trimmed them as necessary and connected them under the balancer with a piece of galvanized pipe in between. I think I just got a 6" nipple from the hardware store and cut off the threaded ends to put the two hose sections together. The hoses butted up and I painted the clamps black. You'd never known it was there. Worked perfect. You don't need anything fancy or expensive to get the job done.
Old Jan 25, 2013 | 10:48 PM
Ram2500's Avatar
Ram2500
Smile
Galvanized really wouldn't have thought about that I've heard copper, stainless, steel and maybe the occasional exhaust tube but galvanized that's a good idea. Thanks Wayne
Old Jan 26, 2013 | 01:41 AM
Rokcrln's Avatar
Rokcrln
I did the same with aluminized exhaust tube in my sons 51. Check out this link and scroll down to pic 5.
https://www.ford-trucks.com/forums/8...n-build-4.html
Kevin
LFD Inc.
Old Jan 26, 2013 | 10:01 AM
Ram2500's Avatar
Ram2500
That looks nice and clean, Good job on that. What motor did you stuff in there
Old Jan 26, 2013 | 10:21 AM
homade's Avatar
homade
if it is the case of an inlet or outlet being in the wrong place just have a radiator shop change the inlet or outlet to whereever you need it, no big deal.
Old Jan 26, 2013 | 10:38 AM
Ram2500's Avatar
Ram2500
Yea I thought about that, but after thinking it over I believe I have the solution. Thanks a lot for all the help guys I appreciate it.
Old Jan 26, 2013 | 10:39 AM
Ram2500's Avatar
Ram2500
Never thought I'd be a part of a forum but you know it helps
Old Jan 26, 2013 | 11:52 AM
imlowr2's Avatar
imlowr2
Personally, I wouldn't want a puzzle of pipes crossing over in my engine compartment. Why spend the time to fabricate a pipe that will function but doesn't look like it belongs? It's so easy to move the outlet or even replace the lower tank on a radiator. It's like Homade and I recommended, take it to a radiator shop and have it done correctly. I think you'll be happier in the long run.
Old Jan 26, 2013 | 12:58 PM
Mervy49's Avatar
Mervy49
Let us know what you came up with.
I'm using a crossflow rad turned on it's side and had the same thing going on....the inlet and outlet reversed to the engine.
E30tdf
Sep 18, 2019 05:38 PM
Stinky1
Dec 18, 2012 02:31 PM
444dieselrod
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 7, 2012 10:01 AM
djmac
Dec 30, 2005 12:31 AM
Quikirk
Feb 27, 2003 09:04 PM
