When i search cylinder heads for a 429/460 for 1970 on rock auto it comes up with a set of marshall cylinder heads for 390 bucks per head incuding the 50 dollor core. would these really be a recreation of 1970 429 heads? or just a smog 1978-79 head.
18mm SPARK PLUG HOLES, W/O SMOG & SCREW IN STYLE STUDS CAST DOVE-C, C8VE, C9VE. that sem to be a way easier way than going an finding a junk set of old castings
what i was trying to ask was are they just the same specs as high horsepower heads as the 68-70 heads. because locally around here i cant find those castings
yep. Small chamber, non hardened valve seats. etc. They are the heads. That's why the core charge. If you had a set of those heads you would send them back and they would rebuild them and sell them to someone else.
Check reincarnation-automotive.com for a better deal on BBF cylinder heads.They're located in Tacoma Wa.One of the most knowledgeable BBF engine specialists anywhere.They have good prices on the parts you're looking for.Scotty J(at reincarnation auto) is a much better resource than ebay or Rock auto.
