6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 Mods
Old Jan 24, 2013 | 07:25 PM
rcorcich's Avatar
rcorcich
6.4 Mods
Hi All, I'm posting this for my buddy who owns a 2008 f-250 6.4 thats all stock except for a bully dog. He would like to know the best mods for best fuel milage , performance and reliability. I think he is running 33's as well ?.
Thanks in advance
Rich
Old Jan 24, 2013 | 08:33 PM
longview1's Avatar
longview1
Banned
Start by tossing the bully dog and removing the dpf/egr systems.
Old Jan 24, 2013 | 08:41 PM
RM2738's Avatar
RM2738
I second that. ^^^^ he better hurry up as the EPA has begun cracking down on the removal/disabling of mandated emissions control devices.
Old Jan 25, 2013 | 05:08 AM
senix's Avatar
senix
Bully dog is his biggest problem.
Old Jan 25, 2013 | 09:25 AM
Scornwell's Avatar
Scornwell
Cold air intake. I've got the AFE stage 2 and I gained about 1 MPG.
Old Jan 25, 2013 | 10:19 AM
kstiner's Avatar
kstiner
What is wrong with the bully dog? And what is the best dpf kit to get/ and tuner. Sorry to ask. I have a 2008 f350 drw that came with the bully dog gt from a dealer ( go figure ) was thinking of doing the delete kit but not sure which one to get. I like the gt unit to monitor the engine I don't us it for power. Thanks. Be nice to me I don't know a whole lot about this 6.4 yet
Old Jan 25, 2013 | 10:56 AM
senix's Avatar
senix
I all you are doing is monitoring your vitals then it is ok.
I have the banks 6 gun for dpf on tunes.
Bully dog is not a clean tune to work with the dpf.
Old Jan 25, 2013 | 06:47 PM
longview1's Avatar
longview1
Banned
The "best" tuner to get is/will be debatable... If you want to keep the DPF on Senix can tell you about the Banks system. If you want DPF off & tuning either Spartan/HS/SCT are the "best". H&S will be harder to come by as of the EPA stuff going on, different folks tune on the livewire, such as matt@gearhead I believe (maybe he uses the minimax? Im not sure) and innovative tunes, etc.
Old Jan 25, 2013 | 07:09 PM
rcorcich's Avatar
rcorcich
Is it worth opening the intake and exhaust ?
and if he finds a good shop to remove the egr and dpf , with a good tune
what kind of milage can he look foward to.
I've read that the 6.4 can make great power when needed, and can greatly improve fuel milage when properly tuned.
He's in the Houston area, any recommendations on a shop that could direct him in the right direction.
Thanks
Old Jan 26, 2013 | 07:11 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
Hope this don't start a Debate
He could look for 1-2mpg better than stock IMHO.
I deleted my Cat, DPF, both EGR Coolers, EGR Valve & Aftermarket Intake
The Very Best I can get babying the truck & NEVER getting above 2,000 rpm is ONLY 16.3 mpg = Hand Calculated.
I'd hate to see the mpg drop if I was towing.
The Lie-O-Meter in Dash makes Ford look good.
I don't see the 6.4 getting 20+ mpg ever .... Like a lot of guys claim.
Now the old 7.3 & 6.0L would easily get 20+
Old Jan 26, 2013 | 10:31 AM
Delta2142's Avatar
Delta2142
I have a 08 Duper Duty I use the Edge Evaluation in economy mode and have added the AFE stage 2 cold air system and I average 14 on the hwy. I do still have the DPF and Cat,
Old Jan 26, 2013 | 12:06 PM
senix's Avatar
senix
I just did a round trip to go pick up the college kid.
18.2 in 27 deg weather. 170 miles.
Old Jan 26, 2013 | 07:56 PM
kstiner's Avatar
kstiner
Thanks for the info. New to all of this, Is there any way to turn off the regen and still use my Bully dog to monitor the truck. I would also like to know if you have to remove the DPF and cat if you just turn off the regen. I hope I am asking this right.
Old Jan 26, 2013 | 07:58 PM
senix's Avatar
senix
If you leave the dpf on without ever going thru a regen then you will clog it up.
so you must remove if you tune unless you use a dpf on tune..which then also means you will still have some regening.
Old Jan 27, 2013 | 07:15 PM
kstiner's Avatar
kstiner
That is kinda what I was think but wanted to make sure Thanks.
Has any one tried to remove the inside of the DPF (If it even can be done). Kinda like the old cat's on cars that you could cut a hole in the top and re install it to look like it was stock. Just wondering. I would like to keep it as stock as possible.
