2000 7.3 electrical problems
Old Jan 24, 2013 | 06:33 PM
watatrp's Avatar
watatrp
Trying to diagnose a problem w/ my daughter's Excursion. 2000 w/ 7.3. Died the other day while running. Found out that one battery is completely discharged. The other is fine. Batteries are less than six months old. Took the battery in and it can be charged and holds a charge. Put it back in and after driving for a few miles, the battery is losing it's charge again. Alternator is putting out almost 13v. My guess is the wiring to the bad battery is bad. Both batteries should be connected to each other right? Seems like the battery that is losing it's charge is not connected to the alternator. When it dies, takes a jump to restart. Any ideas?
Old Jan 24, 2013 | 06:38 PM
BigAlsPSD's Avatar
BigAlsPSD
The batteries are hooked to each other in parallel, positive to positive, negative to negative(although the neg is not directly wired to each other in this case), and the alternator from the factory has just the one positive wire attached to the DS battery.
Old Jan 24, 2013 | 07:13 PM
BWST's Avatar
BWST
Got Data?
13V seems a little low for the alt output. Should be just over 14 I think. Worth checking the connections though first like you're doing.
Old Jan 24, 2013 | 07:20 PM
srteach's Avatar
srteach
https://www.ford-trucks.com/forums/1...tor-issue.html
Take a look at that information. Read all the posts, since I won't retype it. Thread from earlier today, same situation.
The alt should be putting 14-16V out when running. 13V is too low to run the truck and charge the batteries.
Old Jan 24, 2013 | 07:38 PM
watatrp's Avatar
watatrp
That is too funny. That's my son-in-law. Guess he's taken it on himself to learn about his own diesel. Sounds like he's headed in the right direction. Might be in my garage this weekend replacing an alternator. Spent enough time yesterday running his family around. He owes me dinner.
Old Jan 24, 2013 | 07:44 PM
srteach's Avatar
srteach
You might be replacing an alt this weekend, too.
WAIT A MINIT!!! I've been help you and him on the same truck for the same problem?!?!? Damn!
Old Jan 24, 2013 | 09:46 PM
howellt39's Avatar
howellt39
If that ain't good for double reps I don't know what is.
Old Jan 25, 2013 | 08:22 AM
srteach's Avatar
srteach
I've never asked for reps. Don't really care about them, that's not why I'm on FTE (and only FTE). I'm here to help, just like others have for me.
Old Jan 25, 2013 | 11:51 AM
crop harvester's Avatar
crop harvester
if that bad battery is internally shorted,you might not be able to diagnose the alternator until batteries are taken care of first.hopefully the batteries haven't already killed the alt.
Greg5OH
Dec 26, 2012 07:53 PM
Rhino1980
Dec 10, 2010 03:41 AM
78Southwind
Dec 27, 2008 02:15 PM
georgiaford67
Dec 3, 2007 10:57 AM
Smalltar
May 29, 2007 05:44 PM
