crap behind cargo light assembly
Old Jan 23, 2013 | 09:38 PM
alchemist1's Avatar
alchemist1
couple questions-
is there supposed to be stuff akin to Dow's Great Stuff behind the cargo light assembly? I pulled it out and behind there was that yellowish looking dried foam. Thinking previous owner/idiot put it there??
Correct bulb = 1076? Thinking yes, but my owner's manual has it wrong...
Old Jan 23, 2013 | 10:31 PM
VocaTexas's Avatar
VocaTexas
Sounds like there may have been a leak there and the PO tried to seal it with foam.
The bulb depends on the year model. They changed the cargo light styles in '77, I believe. My '76 Crew has a large bulb; 1156 if I recall.
Old Jan 24, 2013 | 12:09 AM
TexasTrash's Avatar
TexasTrash
before serial # Y60,001 - 74/77 - 1156 bulb
from serial # Y60,001 - 77/79 - 912 bulb
Since you have a 74 and 77 in your signature I posted both.
If you have the push and turn type its 1156. The other one just pushes in.
1076 bulb says it was for 73 only.
Old Jan 24, 2013 | 05:58 AM
alchemist1's Avatar
alchemist1
Thanks. On the bulb, the socket has two spring loaded terminals whereas a 1156 bulb has just one. I pushed & turned in an 1156 and it shorted the terminals and blew fuse. The 1076 'looks' right? And interestingly the owners manual calls for a 1156.
Old Jan 24, 2013 | 05:59 AM
alchemist1's Avatar
alchemist1
And interestingly my owners manual does have the 1156 spec'd as the bulb.
Old Jan 24, 2013 | 06:40 AM
TexasTrash's Avatar
TexasTrash
Is this on your 74, If the socket has two pronges in it, I would try the 1076 bulb.
Old Jan 24, 2013 | 07:10 AM
alchemist1's Avatar
alchemist1
Yes. On my 74. Apologies I didn't make it clear. My mfr date is 6/74. Not sure where the s/n is.
Old Jan 24, 2013 | 07:35 AM
TexasTrash's Avatar
TexasTrash
Sometimes you see parts and they say "Before or from ser" thats the last 6 in your vin. If your truck does take the 1076 bulb thats kinda weird since its listed as 73 only. Maybe someone broke that socket at some point and replaced it with one of the 2 pronge ones. The bulbs are basically the same except for the connectors.
Old Jan 24, 2013 | 07:44 AM
alchemist1's Avatar
alchemist1
Ah, yes. the candle power of both 1076 and 1156 is 32. Pretty bright! But to be sure, my truck is a 74, and nearly at the end of the manufacturing run for that year as well.
Thanks everyone.
pyro2
13
Sep 27, 2014 12:38 PM
mastergunner
1997 - 2003 F150
Dec 12, 2013 01:39 PM
FordPickup460
Aug 24, 2005 06:32 AM
billsco
Garage & Workshop
16
Nov 1, 2003 06:14 AM
