drive shaft conversion
Old May 28, 2003 | 04:09 PM
labrouse's Avatar
labrouse
I have a 1960 F100 that I have put a 5.0 mustang engine with a C-4 transmission. The original transmission in the truck was a 4 speed in which the drive line attached to the tranny at a U-joint. I would like to know if it would be best to use the stock driveline from the truck (two piece) and have a yolk welded on to fit the C-4 or if I could use something different that would work. I am looking at $250 to $350 to have the modification done ie welding, yolk, balanced. Any input would help.
Ian_C
Mar 9, 2015 09:22 PM
jackpiner57
1997 - 2003 F150
Jan 28, 2010 06:50 PM
McLeod
Mar 17, 2009 08:49 PM
engine57a
Aug 20, 2006 06:07 PM
Smokinfool9
1997 - 2003 F150
Feb 11, 2005 06:22 PM
