Sponsored by: Auxito
Universal joint installation problem
Old Jan 25, 2010 | 10:47 PM
jackpiner57's Avatar
jackpiner57
I have a 2001 F150 4 x 4 with the 7700 lb. package, regular cab, 8' box and a 5.4 L engine. There are 75,000 mi. on the truck. I am replacing the universal joints in the rear driveshaft. The problem I am having, is that I can't get both bearing cup retaining clips in on the yolk for the short front splined shaft that slides into the transmission. I have used a clamp to bring both cups together, but there's still not enough room. I can get the clip into one side, but not the other. If I center them in the yolk, I cannot get a clip in either side. The U-joints are Federal Mogul and I wonder if they're out of spec. or if anyone else has had problems with them.
Old Jan 26, 2010 | 07:34 AM
fordtech08's Avatar
fordtech08
have you checked the cups to see if a bearing fell into the bottom of the cup keeping it out further?
Old Jan 26, 2010 | 11:48 AM
jackpiner57
I'll remove the cups and check. I was very careful not to let that happen, but I guess it could have. It's the only reasonable explanation.
Old Jan 26, 2010 | 12:31 PM
1975IH200's Avatar
1975IH200
Yep, you've got to be sure those needle bearing stay in their place.
That happened to me once, and I thought I was going crazy.
Also be sure you don't pack it with grease prior to installation, lube it after it is installed in the yokes. Too much grease can also cause this problem.
Old Jan 26, 2010 | 12:45 PM
fordtech08's Avatar
fordtech08
also do the cups touch the center because if they do then you might have gotten the wrong u-joint or your ears are pushed in to far on the yoke
Old Jan 27, 2010 | 12:25 AM
jackpiner57
Thanks guys, that was the problem. I put the roller back in place and put the cup on the shaft and it did it again! Then I put more grease in the cup and spread it around evenly to hold the rollers in place better. All went well after that. I appreciate the help.
Old Jan 27, 2010 | 07:27 AM
fordtech08's Avatar
fordtech08
we have all been there when I was first starting out working on cars I hated to see u-joints
Old Jan 28, 2010 | 10:05 AM
fireball 440's Avatar
fireball 440
LOL yep been there. After that's mastered it's a gravy money maker, front axle joints were a big money maker too, get em for ball joints too almost every time on those crappy twin i beam axle Fords.
Old Jan 28, 2010 | 06:50 PM
muddyford911's Avatar
muddyford911
haha, im no stranger to the "gravy tickets" as we used to call them
Gigemags05
15
Oct 12, 2014 07:25 AM
Junkman of Delaware
2004 - 2008 F150
Jan 17, 2012 11:13 PM
engine57a
Aug 20, 2006 06:07 PM
Smokinfool9
1997 - 2003 F150
Feb 11, 2005 06:22 PM
