Weird electrical problem
Old Jan 23, 2013 | 11:40 AM
Aviator1970's Avatar
Aviator1970
Been noticing for about a week now, that when going down the highway (60-70mph), when I turn on the rt turn signal to change lanes, my auto transmission downshifts. It doesn't do this when applying the left signal. I noticed last night that my left rear brake/turn light is inop. There is no indication on the dash that a bulb is out. Front signal flashes at the normal rate. Any ideas?
Old Jan 23, 2013 | 11:56 AM
88n94's Avatar
88n94
Vehicle year and which transmission?
Old Jan 23, 2013 | 12:03 PM
Aviator1970
96 F250 XLT 2WD. E4OD I believe.
Old Jan 23, 2013 | 12:23 PM
Phy's Avatar
Phy
Are you sure the trans is actually downshifting? Could it be that the torque converter is un-locking? The PCM un-locks the TC when the brakes are applied, and senses this via the brake lights. When bulbs are out, the PCM can get confused.
Change the bulb & see what it does...
Old Jan 23, 2013 | 12:42 PM
Aviator1970
Ok, I'll give that a try. I had a '92 F250 that, over a several month period, lost ABS, then the speedo quit, and finally the truck wouldn't shift out of low. An honest tranny mechanic told me to fix the speedo and see what happened. I changed the ABS/speed sensor in the differential (a $20 part) and everything that had been slowly going wrong was fixed. So I've seen strange things with these trucks. I didn't equate this problem to a bulb because the dash indicator and front signal still flash at the normal frequency instead of rapidly, which is what I would expect from a bad bulb.
Thank you for the advice. I'll post the results here tomorrow.
Old Jan 23, 2013 | 01:18 PM
88n94's Avatar
88n94
There are a couple small wires that go through the shift lever to that switch on the end of the shift lever. I imagine that plastic piece under the steering wheel that cancels the turn signal lever when the turn is completed, is hitting one of those wires and shorting it against something metal. A bare spot in one of those insulated wires. Something on that order anyway. That would be my guess.
Old Jan 23, 2013 | 06:09 PM
Phy's Avatar
Phy
The fast flashing when a bulb is burned out is a function of a standard flasher. A heavy duty flasher (commonly used for towing) doesn't change the flash rate depending on lamp resistance like a standard flasher will, to accommodate the extra lamps on the trailer...
SSStang
Feb 28, 2018 11:59 PM
WisconsinF150
2004 - 2008 F150
Dec 16, 2011 08:48 PM
anteru
Jul 21, 2010 04:53 AM
jbbroncoII
Bronco II
Nov 21, 2006 08:06 PM
erik_herrling
1997 - 2003 F150
Jul 18, 2003 01:27 PM
