P1280
Old Jan 23, 2013 | 07:49 AM
vczar1's Avatar
vczar1
P1280
I did a CCV MOD and washed the engine with simple green and a garden hose yesterday, started the truck and it was running fine for about 10 min. After that it started spattering and a P1280 code poped up. Is it related to a wash or ccv? It does not stoll but idles bad, drives fine once i get it over about 5mph.
Old Jan 23, 2013 | 01:15 PM
Stewart_H's Avatar
Stewart_H
Instead of typing the info, because this is covered so often, I figured I'd quote a post for ya and found a post by Curtis.
Ya can't get any better than his words, in this post, for your problem, in starting the diagnostic process of fixing your problem.
Originally Posted by Pocket
Do you have a chip or tuner on your Ex? If so, the P1280 is common. If not, you may have something going on.
The ICP stands for Injection Control Pressure. Basically the injectors fire using high oil pressure that can range from 500psi at idle to close to 3000 psi at WOT. These engines have a high pressure oil pump (HPOP) that sits directly underneath the fuel bowl in the engine valley. This pump takes engine oil, pressurizes it, and sends it to the oil rails and to the injectors.
Having the P1280 means that the PCM is reading lower oil pressure at the rails than what is commanded in the programming for a particular engine load. It's common if you have a chip or tuner, since the demands for fueling and oil pressure in higher horsepower tunes typically are more than what the HPOP can physically supply. If you have a chip or programmer and get this code, it's not hurting the engine or anything. It just means you won't get the full power capacity that the chip is calling for.
However, if the truck is stock and you are getting this code, it could indicate a weak HPOP, a bad ICP sensor itself (or associated wiring), or a bad IPR (Injector Pressure Regulator). The way to find out for sure would be to hook the truck up to a diagnostic scanner and watch ICP pressures, duty cycle, and voltage to determine the issue.
Stewart
airjeff
Jan 19, 2013 11:15 AM
desertt5
Jul 5, 2010 12:57 PM
grizzley30814
Feb 10, 2008 07:56 PM
Big Swole
Aug 12, 2007 06:00 AM
thinksnow
Feb 11, 2005 05:51 PM
