67 fuel pump problem?
Old Jan 21, 2013 | 03:28 PM
zgraham's Avatar
zgraham
I just bought a '67 F100 with a 352 and auto tranny. I had to put a new fuel line from the fuel pump to the carb on it. I also put in an in-line fuel filter. The truck was empty so I put 2 gallons in the gas tank. I pumped the gas pedal several time and still haven't gotten any fuel into the fuel filter. The truck has set empty for a while. I has going to take the fuel line loose from the carb and blow air back through to the gas tank to see if there was any blockage. Do you guys think i might need to fick up a new fuel pump?
Old Jan 21, 2013 | 04:22 PM
f5fordgirl's Avatar
f5fordgirl
You can sit there and pump the gas petal for the next 1000 years and you won't get any gas to the carb. Cranking the engine with the starter is what does that.
Old Jan 21, 2013 | 04:26 PM
zgraham's Avatar
zgraham
I have tried that too, still no gas.
Old Jan 21, 2013 | 04:59 PM
jowilker's Avatar
jowilker
Try removing the tank side line at the fuel pump, remove the filler cap and blow compressed air through the line to see if gas will start flowing. Reconnect, then see if it will pump gas up to the carb.
You can also put some gas in a empty water or pop bottle and pour a couple swallows into the carb to see if it will fire and start pumping gas.
John
Old Jan 21, 2013 | 08:19 PM
RichS2659's Avatar
RichS2659
Replace the fuel filter located under the fuel pump first, then replace the pump if needed.
Old Jan 21, 2013 | 08:48 PM
67-F100's Avatar
67-F100
You can try taking the pump off and hand pump the lever on the pump to see if it does anything, then check the lines from the tank to pump
eclectix
1966 - 1977 Early Broncos
Jul 17, 2017 08:26 PM
Ego Flat 48
Oct 9, 2008 09:11 PM
ericeugunep
Aug 24, 2008 07:56 PM
DeanBob
Aug 22, 2007 10:30 AM
nealjpage
Dec 30, 2004 11:58 PM
