67 fuel pump problem?
Old 01-21-2013, 03:28 PM
zgraham's Avatar
zgraham
zgraham is offline
I just bought a '67 F100 with a 352 and auto tranny. I had to put a new fuel line from the fuel pump to the carb on it. I also put in an in-line fuel filter. The truck was empty so I put 2 gallons in the gas tank. I pumped the gas pedal several time and still haven't gotten any fuel into the fuel filter. The truck has set empty for a while. I has going to take the fuel line loose from the carb and blow air back through to the gas tank to see if there was any blockage. Do you guys think i might need to fick up a new fuel pump?
Old 01-21-2013, 04:22 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
You can sit there and pump the gas petal for the next 1000 years and you won't get any gas to the carb. Cranking the engine with the starter is what does that.
Old 01-21-2013, 04:26 PM
zgraham's Avatar
zgraham
zgraham is offline
I have tried that too, still no gas.
Old 01-21-2013, 04:59 PM
jowilker's Avatar
jowilker
jowilker is offline
Try removing the tank side line at the fuel pump, remove the filler cap and blow compressed air through the line to see if gas will start flowing. Reconnect, then see if it will pump gas up to the carb.
You can also put some gas in a empty water or pop bottle and pour a couple swallows into the carb to see if it will fire and start pumping gas.
John
Old 01-21-2013, 08:19 PM
RichS2659's Avatar
RichS2659
RichS2659 is offline
Replace the fuel filter located under the fuel pump first, then replace the pump if needed.
Old 01-21-2013, 08:48 PM
67-F100's Avatar
67-F100
67-F100 is offline
You can try taking the pump off and hand pump the lever on the pump to see if it does anything, then check the lines from the tank to pump
eclectix
1966 - 1977 Early Broncos
07-17-2017 08:26 PM
Ego Flat 48
10-09-2008 09:11 PM
ericeugunep
08-24-2008 07:56 PM
DeanBob
08-22-2007 10:30 AM
nealjpage
12-30-2004 11:58 PM
Quick Reply: 67 fuel pump problem?
