Engine build
Old Jan 25, 2013 | 09:58 AM
Conanski's Avatar
Conanski
The cylinder head exhaust port location and bolt pattern is the same on all Ford and aftermarket heads made for this engine series... with the exception of a few nascar specific castings, so those headers will bolt up fine.. the only issue you may encounter is how well they fit the truck.
Old Jan 25, 2013 | 10:02 AM
FordYoungGun35's Avatar
FordYoungGun35
Should I look into shorties then or is there that much of a difference? It will have a 3 in single exhaust
Old Jan 25, 2013 | 10:06 AM
Conanski's Avatar
Conanski
Shorties are only slightly worse than longtubes and much better than manifolds as long as you don't use the stock Y pipe and cats.
Old Jan 25, 2013 | 10:08 AM
FordYoungGun35
Well you know from my past posts that right now in running shorties on a relatively stock motor and the whole exhaust is 3 in so ill be able to tell a difference I'm sure.. The whole system is custom
56fordguy
Oct 7, 2011 11:37 AM
stephenfaustin
Oct 1, 2009 03:53 PM
lr
Sep 19, 2005 11:03 AM
stinkinlinkin
Nov 23, 2004 08:28 AM
JBronco
1978 - 1996 Big Bronco
Jul 31, 2003 09:28 AM
