87 f150 ignition problems
Old Jan 19, 2013 | 09:04 PM
68fordf100v8's Avatar
68fordf100v8
Alright guys i have changed the starter, solenoid, ignition switch, ignition actuator, ignition module under the dash on the steering column
but still every time i turn the switch it does nothing all the lights and gages work any ideas?
Old Jan 19, 2013 | 11:12 PM
88n94's Avatar
88n94
You changed the ignition switch that is a foot or so down the steering column from the key?
What kind of transmission do you have, automatic or manual?
Old Jan 20, 2013 | 02:40 AM
68fordf100v8
I have changed the ignition switch and the transmission is a c6
Old Jan 20, 2013 | 07:05 AM
tjc transport's Avatar
tjc transport
i ain't rite
did you shift between park and neutral while trying to start?
it may not be all the way in park, or the neutral safety switch may be bad
Old Jan 20, 2013 | 11:52 AM
88n94's Avatar
88n94
I totally agree. Also if your ignition switch isn't adjusted up far enough toward the steering wheel, it will cause the problem you are having.
A little history leading up to the problem usually helps. What was the first thing that happened, say a broken ignition actuator?
Old Jan 20, 2013 | 08:58 PM
68fordf100v8
at first it would start with the key one day and the next it wouldn't start with it but after changing all the ignition and it still not working i will just put a push button ignition and be done with it
Old Jan 21, 2013 | 12:18 AM
88n94's Avatar
88n94
First I would lower the steering column and slide the ignition switch as far as possible toward the steering wheel. Then try to start it with the key. If it does start, you may have to slide the ignition switch away from the steering wheel some and fine tune the adjustment.
Luko
13
Nov 24, 2017 01:05 PM
loganmick
16
Jul 11, 2015 05:09 PM
johnsteffy
Dec 31, 2010 12:09 PM
jrv
May 16, 2008 08:49 PM
masonmachines
Jun 15, 2004 09:37 PM
