Sponsored by: Auxito
97 front brake chatter when cold
Old Jan 17, 2013 | 06:52 PM
bluehog's Avatar
bluehog
7th Gear
Question 97 front brake chatter when cold
Hey everyone ~
I could use some advice on my 97 F150 4.6 4x2. I have a semi-rough front end "chatter" when the brakes are first applied after vehicle has been sitting overnight. It feels like it comes from the front disk brakes, I assumed it was a warped rotor or loose wheel bearing so I replaced the front rotors (old were to thin to turn), new wheel bearings and pads. Still had the issue, so I then assumed it was a bad caliper... replaced both those, and all related hardware. Still have the issue!
I can not reproduce the event until the vehicle is in the cold state and it will only do it once or twice, so I am finding it difficult to diagnose. Any suggestions? Tired of blindly attacking this issue by changing what I thought was obvious.
F150, 130K miles, 4.6l, automatic, 4x2, rear drums, front disk
Old Jan 17, 2013 | 11:38 PM
Bluegrass 7's Avatar
Bluegrass 7
Give some idea of how tight you make the lug nuts on the front discs.
Could you be over tightening them and distorting the discs?
Front wheel balance, loose steering box, linkage or ball joints?
Tires take a cold set until they begin to heat?
Old Jan 18, 2013 | 04:40 PM
bluehog's Avatar
bluehog
7th Gear
Bluegrass 7 ~
thanks for the tips... I did use a torque wrench for the lugs @ 125ftlb. I will rotate the tires and see if I have any difference. I wil also inspect the other steering linkages as well. Hope to find something and put this behind me. thanks again.
sirvexbruzer
Sep 29, 2014 08:54 PM
amkkba
Feb 6, 2010 08:00 PM
DOUG5G
Aerostar
19
Oct 9, 2007 02:11 PM
F250redding
Dec 11, 2004 09:28 PM
89MustangGX
May 24, 2004 06:00 PM
