How much money do you wanna spend on the lift? You could go with a fabtech. For a couple hundred more dollars they ride and perform better in the dirt.
Either way if you go with a 4 or a 6 inch 35's would look good. But if you getthe 6 inch you might want to go with 37's. Do you have 4x2 or 4x4?
Fabtechs also make your ride quality alot smoother, at least it did it for me. When the truck would go over bumps it would feel like the rear end is swaying to the right or left and the lift stopped that. Also the fabtech lifts are reall strong
With the 3.5" hanger kit you may have to trim in the front for 35" tire clearance, depending on your wheel offset........5.5" will clear 35's no problem
tonetone313,
I have a set of 5.5" Fabtech springs I took off of my excursion that you can have if you pick them up. I also have a set of Procomp Xtreme all-terrain 37x13.5x18 tires for sale. I got a new super duy so I lowered the excursion down to 3" for the wife.
I have a procomp 6"lift and am very pleased with it . Now I like my ex riding like a truck and not a car . I also have procomp exterrian 35" like the look but are alittle much on my daily.
