Lockouts stripped????
Old Feb 13, 2013 | 07:04 AM
run6.0run's Avatar
run6.0run
Originally Posted by Headviking
to test if it's engaged. Do this. Put the truck into 4x4 and turn off the truck. Crawl under the front end and grab a hold of the front u-joint just before the back of the hub. See if it turns. If it does not turn it's locked, if it turns that's the hub that needs to be taken care of.
I'm aware of that, thx tho. But the question isn't about the engagement if the hubs, it's about the condition of the wheel bearing hub causing it to pull while engaged. But, the last time I had to use the 4wd, it worked flawlessly. Oh well. I'm happy.
Old Feb 22, 2013 | 11:41 PM
run6.0run's Avatar
run6.0run
Well,, it's fixed!!!! I replaced the PVH,,, which wasn't putting out any vacuum, So then,,, I replaced one lockout cause it was sticking and not unlocking. That seemed to work. But it ended up still giving me problems. The other old lockout started sticking so I replaced it. They both had over half a million miles on them. The driver side continued to not function with the esof. I checked all the vacuum lines n everything checked out so I was scratching my head. After thinking about it,,, I decided to take a blow gun to the vacuum fitting on the hub with the lockout removed,,,, the freakin channel that feeds the hub with vacuum was clogged with grease. After cleaning it out,,, it actually works like it should. It locks n unlocks as it should.
So I thought I'd let everyone know that my problem was grease being vacuumed into the hub from the lockout and clogging the hub. It vacuumed down, but the vacuum wasn't reaching the lockout. It's a good day.
Old Feb 23, 2013 | 12:10 AM
Yahiko's Avatar
Yahiko
Was it over greased in the past?
How ever it happened you got it fixed. That is what counts.
Sean
Old Feb 23, 2013 | 08:34 AM
run6.0run's Avatar
run6.0run
Over greasing???? Yes. I put a film over the lockouts about 300k ago. Obviously the film was too thick. Lol.
fawzi.mufti
Jun 12, 2017 08:58 PM
sammie0126
Mar 17, 2013 10:02 PM
Lloydable
Apr 10, 2012 11:30 AM
yasky69
Modular V10 (6.8l)
30
Jan 22, 2011 09:35 PM
robinsonpowerstroke
Aug 3, 2010 07:33 PM
